Freebird Posted June 6, 2019 Posted June 6, 2019 Did my first oil change on the SVTC today. Easy enough. A bit more work than the RSV and a bit less work than the Harley Road Glide. Not a big job though. Odometer has 601 miles so I was pretty dang close to their 600 mile spec. My old Craftsman lift worked fine, no adapter required. Note though that I didn't actually lift the bike, just used the lift to level it.
Marcarl Posted June 7, 2019 Posted June 7, 2019 Now that you did that, isn't it about time to give it a good wax job?
dave_wells Posted June 7, 2019 Posted June 7, 2019 I just had my 600 mile service done. Cost 241.00 one more service visit, after that I will do my own oil changes. I am curios about what is involved with tire changes and adjusting to belt properly Ill figure that one out next year
sldunker Posted June 7, 2019 Posted June 7, 2019 Hey Freebird, when you did your oil change do you remember which of the side drain screws let out the least amount of oil. I am almost due for my second change and I wanted to send in an oil sample for testing. I want to do this before the oil change and I can't remember which one of the screws it was.
Freebird Posted June 7, 2019 Author Posted June 7, 2019 (edited) I honestly didn't notice that there was a difference. Just took them out and let them run. Sorry. Edited June 16, 2019 by Freebird
hunter 1500 Posted June 9, 2019 Posted June 9, 2019 Did mine and almost ready for the second one. Going to do it at 2k. The more I ride this bike the better I like it. Had a hell of the time getting the filter off. Didn't have the specific slide over type and the one I had was just a little too big so it would slide. Took some duct tape and went around it and it came off. I'm using the K and N filter so I wont have to worry about it.
Freebird Posted June 9, 2019 Author Posted June 9, 2019 I used the Yamaha filter this time but will certainly use the K&N next time. Would make it so much easier. I used a pair of Channel-Lok slip joint pliers to get it off. Was still hard to get the right angle with the lines in the way.
BlueSky Posted June 9, 2019 Posted June 9, 2019 It might be interesting to cut the filter open and see what is inside.
GreenMtnHunter Posted June 16, 2019 Posted June 16, 2019 (edited) Hey Freebird, when you did your oil change do you remember which of the side drain screws let out the least amount of oil. I am almost due for my second change and I wanted to send in an oil sample for testing. I want to do this before the oil change and I can't remember which one of the screws it was. I saw a DYI vid which was suggesting there are three drain plugs! My Road* has two.... Is the filter situated so that I won't be able to use my leather belt to r/r? And, yes, I wear suspenders...;-) Edited June 16, 2019 by GreenMtnHunter added words
Freebird Posted June 16, 2019 Author Posted June 16, 2019 Definitely 3 drain plugs. I didn't have an oil filter wrench, actually I do but didn't find it until the next day, but it looks to me like a small strap wrench would work just fine.
N3FOL Posted September 17, 2019 Posted September 17, 2019 I have the J&S Jack that I use on my '07 RSV and also have the 'Carbon One' lift. Will I be able to use these items on the new '18 Star Venture?
