coop Posted May 22, 2019 #1 Posted May 22, 2019 Hey Guys, Couple questions..... 1) I was looking at my rear shock and right above where the top bolt goes thru the shock eye there's a tab with a hole in it and a rubber bushing above it. I'll try to attach a picture. I have no bolt there. Am I missing a bolt? Is that the battery box above the shock? 2) I searched but couldn't find an answer....best oil for rear drive. One that may eliminate my whine ( I have a v-max final drive) Thanks, Coop
djh3 Posted May 22, 2019 #2 Posted May 22, 2019 Looks like it is welded to the frame there. Hard to say, but you should be able to get a better eyeball on it. Final drive oil I liked a full synthetic . Most "whine" is usually from the clutch basket. But with a lower gear ratio I could believe it makes a bit more noise. I think 70w140 may be the weight I ran, but check the service manual. There are a couple places one is available from download free.
coop Posted May 22, 2019 Author #3 Posted May 22, 2019 Looks like it is welded to the frame there. Hard to say, but you should be able to get a better eyeball on it. Final drive oil I liked a full synthetic . Most "whine" is usually from the clutch basket. But with a lower gear ratio I could believe it makes a bit more noise. I think 70w140 may be the weight I ran, but check the service manual. There are a couple places one is available from download free. Thanks. Yah that bushing has a hole thru it, like takes a bolt. There is no evidence or markings of a nut ever being there. I'm not sure but I think that's the battery box on top. ....I got to get my seat off tomorrow and look at the top side. Coop
Du-Rron Posted May 22, 2019 #4 Posted May 22, 2019 Hey Guys, Couple questions..... 1) I was looking at my rear shock and right above where the top bolt goes thru the shock eye there's a tab with a hole in it and a rubber bushing above it. I'll try to attach a picture. I have no bolt there. Am I missing a bolt? Is that the battery box above the shock? 2) I searched but couldn't find an answer....best oil for rear drive. One that may eliminate my whine ( I have a v-max final drive) Thanks, Coop No bolt is missing. I like all that is synthetic. I use 80W-90. It will all be rated GL5-6
coop Posted May 22, 2019 Author #5 Posted May 22, 2019 No bolt is missing. https://www.venturerider.org/forum/attachment.php?attachmentid=116527 https://www.venturerider.org/forum/attachment.php?attachmentid=116528 I like all that is synthetic. I use 80W-90. It will all be rated GL5-6 Awesome! Thanks much for the pictures! Coop
