Royal Venturer Posted May 10, 2019 #1 Posted May 10, 2019 Ok the title nabbed ya!!! Need to drain the carbs as first resort, sooooo….anybody know the O.D. of the nipples on drains so I can buy appropriate hoses to slip over them?
Royal Venturer Posted May 12, 2019 Author #3 Posted May 12, 2019 3mm;) Thank you, but I'm afraid pulling the carbs is the next step. I let them get gunked from inattention and now I'm paying the price. Do the float bowls on these need new gaskets if opened up? Is there a kit? or will I see what I need when I pull them apart?
Du-Rron Posted May 12, 2019 #4 Posted May 12, 2019 Thank you, but I'm afraid pulling the carbs is the next step. I let them get gunked from inattention and now I'm paying the price. Do the float bowls on these need new gaskets if opened up? Is there a kit? or will I see what I need when I pull them apart? @cowpuc advises to inject carb cleaner through the drains and let em set for awhile before tearing carbs apart. Search his posts to find exact article.
Rafterd Posted May 21, 2019 #5 Posted May 21, 2019 Thank you, but I'm afraid pulling the carbs is the next step. I let them get gunked from inattention and now I'm paying the price. Do the float bowls on these need new gaskets if opened up? Is there a kit? or will I see what I need when I pull them apart? https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F192095629148 these work great.
