If you need a set of 07 RSV forks, I have a set, with no damage at all. Willing to part with them for a fair offer. Sorry cant help with your original question.
Let me know if your interested.
Thanks, Craig
According to Parts Nation the actual fork leg bottoms and fork tubes are same same for both bikes:
O7 RSTD: https://www.yamahapartsnation.com/oemparts/a/yam/50045f49f8700209bc794d9a/front-fork
07 RSV (Venture): https://www.yamahapartsnation.com/oemparts/a/yam/50045f90f8700209bc794e7f/front-fork
But,, of course, the entire assembly shows different Pt numbers so I would say YES, you could swap out the forks themselves with no problem,,, according to the parts diagram..
Hope this helps..
Puc
Hope this helps..
Puc
My guess... Research the spring rates between the RSV & RSTD; the fairing handing on the front end may require heavier springs for the RSV. IF you were going to rebuild the forks anyways it might be as easy as swapping in some aftermarket heavier springs to freshen up the handling.
