The Mayor Posted April 16, 2019 Posted April 16, 2019 Will the forks from a xvz1300ct tour deluxe fit on a venture
Marcarl Posted April 16, 2019 Posted April 16, 2019 I guess that the best thing to do would be to inform us of the years and models, then there would be ideas come forth.
cecdoo Posted April 16, 2019 Posted April 16, 2019 If you need a set of 07 RSV forks, I have a set, with no damage at all. Willing to part with them for a fair offer. Sorry cant help with your original question. Let me know if your interested. Thanks, Craig
cowpuc Posted April 16, 2019 Posted April 16, 2019 According to Parts Nation the actual fork leg bottoms and fork tubes are same same for both bikes: O7 RSTD: https://www.yamahapartsnation.com/oemparts/a/yam/50045f49f8700209bc794d9a/front-fork 07 RSV (Venture): https://www.yamahapartsnation.com/oemparts/a/yam/50045f90f8700209bc794e7f/front-fork But,, of course, the entire assembly shows different Pt numbers so I would say YES, you could swap out the forks themselves with no problem,,, according to the parts diagram.. Hope this helps.. Puc
BratmanXj Posted April 17, 2019 Posted April 17, 2019 According to Parts Nation the actual fork leg bottoms and fork tubes are same same for both bikes: O7 RSTD: https://www.yamahapartsnation.com/oemparts/a/yam/50045f49f8700209bc794d9a/front-fork 07 RSV (Venture): https://www.yamahapartsnation.com/oemparts/a/yam/50045f90f8700209bc794e7f/front-fork But,, of course, the entire assembly shows different Pt numbers so I would say YES, you could swap out the forks themselves with no problem,,, according to the parts diagram.. Hope this helps.. Puc My guess... Research the spring rates between the RSV & RSTD; the fairing handing on the front end may require heavier springs for the RSV. IF you were going to rebuild the forks anyways it might be as easy as swapping in some aftermarket heavier springs to freshen up the handling.
