KAWoodworth Posted December 23, 2018 #1 Posted December 23, 2018 I have a 2007 RSV. I believe my cylinder #4 is not firing. Exhaust pipe cold. I have a feeling it is the ignition coil. I thought the plug wire was attached to the coil and it came as one part. Looking at Partshark and Partsvilla they both list two numbers one for the coil #9 and one for the plug wire #19 . Do I have to order both or does the plug wire come off the coil?
Rafterd Posted December 23, 2018 #2 Posted December 23, 2018 The coil and the wire are one part. The plug cap is the other number. Yours should unscrew and install on the new
CaseyJ955 Posted December 24, 2018 #3 Posted December 24, 2018 Maybe not a bad time to consider COPs. It was easy on my Gen1 Venture and Gen1 Vmax but have never done a Gen2. On the earlier models the wire can be removed and cleaned, this later one with an integral HT lead is different than my two earlier Yammie V4s. https://www.venturerider.org/forum/showthread.php?102440-Run-for-it-it-s-the-COPs!
