StarRider07 Posted May 2, 2008 #1 Posted May 2, 2008 Does anyone have instructions on how to install the thermo switches. Photos would be great. There is a new one that will turn that fan on at 80 degrees. (Thank for that info tx2sturgis) What the other one is for, I don't know but there are 2 switches. Can anyone help with the installation instruction. Thanks
Al Bates Posted May 2, 2008 #2 Posted May 2, 2008 I had to replace the fan thermo switch in my 02 a couple of years ago, the fan was not coming on. Did a little testing and found a bad Fan Thermo Switch. There's two of them one in top of the radiator and I think one in the thermo stat housing. The switch in the radiator is larger and controls the fan and the smaller one turns on the over temp light.
Guest tx2sturgis Posted May 2, 2008 #3 Posted May 2, 2008 There is a new one that will turn that fan on at 80 degrees. (Thank for that info tx2sturgis) Thanks Thanks actually go to SledgeHammer...but your welcome. That is 80 C by the way...something like 160-170F.
KiteSquid Posted May 2, 2008 #4 Posted May 2, 2008 Why would you want the fan to turn on at a different temp than what the factory engineers designed it to?? Also, at what temp is the factory setting???
