While Red hit it right off by cheatingicon8.png Bongo is correct. At the moment you have interrupted the circuit by disconnecting the the Master Control and Front Radio Remote modules. So this assumes that the module is shorted and that may prove to be the case? If you swap out and it starts again you will need to follow through and find that short, which is the blue/white wire from the plug at the start switch at one end and the Radio Control the other end (pin to pin)
So thinking this through, I got to thinking about avoiding this potential via a small relay between the circuit, when it hit me that if there was a short before the module,,, it would still be there dah.
Edited by Patch
