StarRider07 Posted May 1, 2008 Posted May 1, 2008 Where can I start looking for an after market ignition for a 99 Venture? Yamaha wants over $280 for it. Thanks
Squeeze Posted May 1, 2008 Posted May 1, 2008 http://www.dynaonline.com/skins/products/metric_cruisers/dyna_3000/
StarRider07 Posted May 1, 2008 Author Posted May 1, 2008 Mmmm, thanks guys. One of us is confused. When I said ignition, I meant where you put the key and turn. Isn't that the ignition. Anyway, sorry if I was wrong. Aftermarket unit the key goes in. Thanks
gibvel Posted May 1, 2008 Posted May 1, 2008 I had a feeling that's what you meant. I read and re-read your post and decided that it didn't say anything about it being the ignition switch. Okay. I think, with the exception of ebay, you're stuck paying Yamaha for that one. May find one on ebay though. BTW you can get them cheaper on-line. Found one for $117 here: http://www.cheapcycleparts.com/pages/parts/viewbybrand/2/Yamaha.aspx Just put the appropriate info in the first page. When the fiche comes up go to electrical 1. Should be part #6 SKU: 4XY-82501-00-00 MAIN SWITCH STEERING LOCK Even cheaper here: http://www.flatoutmotorcycles.com/fiche_section_detail.asp Just so you know, the original bolts that were used are the kind that the head snaps off when they are tightened. If you plan on doing the work yourself the bolt will have to have a slot cut into what's left of the head so you can use a screwdriver on it. You'll either have to reuse those bolts, if you can, buy some new bolts # 7 on the list, or find the appropriate replacement bolts at a hardware store.
Eck Posted May 1, 2008 Posted May 1, 2008 Where can I start looking for an after market ignition for a 99 Venture? Yamaha wants over $280 for it. Thanks J&P Cycles Call them...they say: Tell us your motorcycle. We'll tell you what fits. or... you can go with a 'universal replacement switch"...Popular as an OEM replacement..!! $14.99 http://www.jpcycles.com/productgroup.aspx?GID=11421E92-AE01-4118-A00B-C67E775E34ED
StarRider07 Posted May 1, 2008 Author Posted May 1, 2008 I had a feeling that's what you meant. I read and re-read your post and decided that it didn't say anything about it being the ignition switch. Okay. I think, with the exception of ebay, you're stuck paying Yamaha for that one. May find one on ebay though. BTW you can get them cheaper on-line. Found one for $117 here: http://www.cheapcycleparts.com/pages/parts/viewbybrand/2/Yamaha.aspx Just put the appropriate info in the first page. When the fiche comes up go to electrical 1. Should be part #6 SKU: 4XY-82501-00-00 MAIN SWITCH STEERING LOCK Even cheaper here: http://www.flatoutmotorcycles.com/fiche_section_detail.asp Just so you know, the original bolts that were used are the kind that the head snaps off when they are tightened. If you plan on doing the work yourself the bolt will have to have a slot cut into what's left of the head so you can use a screwdriver on it. You'll either have to reuse those bolts, if you can, buy some new bolts # 7 on the list, or find the appropriate replacement bolts at a hardware store. Thank you so much.
gunboat Posted May 1, 2008 Posted May 1, 2008 hi you might try pinwallcycles. they have used parts for our bikes. i have purchased several parts from them and have been very pleased with their service. there is a link to their site on the right hand side of the forms page best reguards don c.
SaltyDawg Posted May 1, 2008 Posted May 1, 2008 Check with Rick at http://www.buckeyeperformance.com tell him you belong to this site.
1BigDog Posted May 1, 2008 Posted May 1, 2008 6http://www.ysppart.com/common/images/icoPartSuper.gif Loading... SKU: 4XY-82501-00-00 MAIN SWITCH STEERING LOCK1$122.09http://www.ysppart.com/modules/oemparts/images/partsadd.gif www.ysppart.com Yamaha Sports Plaza .....great service and quick delivery.
BOO Posted May 2, 2008 Posted May 2, 2008 I think somewhere around here there is an article showing how to repair/rebuild the ignition switch. It might be over at Venturers.org site. But I've seen it somewhere. On the other hand, $120 sounds like a fairly good price for a new one. Jerry
Al Bates Posted May 2, 2008 Posted May 2, 2008 Zanotti 724.283.5419 https://www.zanottimotor.com/shopping/partLookUp.html Description - Main Switch STEI Part Number 4XY-82501-02-00 (thats for my 02 should be the same for all 2 gens) $102.74 I ordered on line.
