M61A1MECH Posted September 14, 2018 Posted September 14, 2018 (edited) Just changed the tail lights on my Bushtec Roadstar to LEDs, I used some form Superbrightleds and they are great. Here is a link to what I used, https://www.superbrightleds.com/moreinfo/tail-brake-turn/1157-can-bus-led-bulb-dual-function-26-smd-led-tower-bay15d-retrofit-car/1166/ These are currently on clearance for $9.88 each. These are oversized and are the longest you will be able to fit in the Harley light fixture that Bushtec uses, in fact at first I thought I screwed up because the end of the bulb seemed to be touching the inside of the lens cover, but with a bit of patience I was able t get it to all go together. Edited September 14, 2018 by M61A1MECH
