Freebird Posted September 11, 2018 Posted September 11, 2018 Installed the luggage rach last night. Very nice that Yamaha marked the location where you were supposed to drill the holes. Made it very simple to install. I usually measure many times before I start drilling because it's hard to "un-drill" a hole. The lid construction is certainly different from any other bikes I've ever owned. If you haven't installed a rack or look at the lid, it is a double lid construction. There are 24 screws I think that hold the top (painted) skin of the lid onto the base of the lid. You remove those screws and lift the top lid off and there are 4 tiny "x" marks molded into the bottom side of the top lid. That is where you drill the holes. Very simple. They call for drilling a 1/8" pilot hole and then a 10mm hole for the bolts. I didn't have a 10mm bit but used did have a 25/64" bit which is the fractional equivalent. That worked fine. It does surprise me that they list something like 4.4 lbs. for the maximum load on the rack. I think the RSV was 10 lbs. I'm sure I exceeded that many times and never had any issues with it. This lid seems much stronger than the one on the RSV.
ChiefGunner Posted September 11, 2018 Posted September 11, 2018 Installed the luggage rach last night. Very nice that Yamaha marked the location where you were supposed to drill the holes. Made it very simple to install. I usually measure many times before I start drilling because it's hard to "un-drill" a hole. The lid construction is certainly different from any other bikes I've ever owned. If you haven't installed a rack or look at the lid, it is a double lid construction. There are 24 screws I think that hold the top (painted) skin of the lid onto the base of the lid. You remove those screws and lift the top lid off and there are 4 tiny "x" marks molded into the bottom side of the top lid. That is where you drill the holes. Very simple. They call for drilling a 1/8" pilot hole and then a 10mm hole for the bolts. I didn't have a 10mm bit but used did have a 25/64" bit which is the fractional equivalent. That worked fine. It does surprise me that they list something like 4.4 lbs. for the maximum load on the rack. I think the RSV was 10 lbs. I'm sure I exceeded that many times and never had any issues with it. This lid seems much stronger than the one on the RSV. I like the design of their rack, but I wish it wasn’t all blacked out. I have to pay for the rack and then pay extra to have it chromed. Will do the same with the saddlebag kid rails. If I were you, I’d use those base supports available at JP cycles that spread the foot pad stress over a wider area. And what up with this 4lbs junk? My winter coat is heavier than 4lbs! In your opinion, do you think it’ll support more weight without an issue? Just curious. Guess I should’ve read your WHOLE post before jumping in! So, based on what you see in the trunks construction, it’s sturdier than the RSV. I used to put 10lbs on the one in my 91 VR with no problems. Never had a stress crack at all.
turtle Posted September 11, 2018 Posted September 11, 2018 I do know Mike the Diamond Cut guy has diamond cut make it look a lot better. IMHO
ChiefGunner Posted September 11, 2018 Posted September 11, 2018 I do know Mike the Diamond Cut guy has diamond cut make it look a lot better. IMHO Interesting idea. As long as it’s not too deep of a cut and might actually match the fins on the engine. 🤔
djh3 Posted September 12, 2018 Posted September 12, 2018 On my Victory I added Kuryakin foot things. They displace the weight some and I added big fender washers under the lid.
Freebird Posted September 12, 2018 Author Posted September 12, 2018 The luggage rack design is fine on the top side. The top brackets are wide enough and are solid between each mounting screw. The underside may benefit from some flat straps between the holes. Would be easy enough to make. Just a couple 6 or 8" pieces of flat strap aluminum or SS and drill holes in each end. I will probably do that at some point. I don't know why the load rating is so low. This trunk does seem stronger than the one on the RSV and the First Gens. I'm taking a bit different approach on this bike. My last bike had pretty much every piece of chrome that was available from Yamaha and the aftermarket. I've pretty much reached the decision that I'm going to limit myself to items that I feel are really needed this time for either comfort, utilization, or safety. At first, I looked around for any new chrome goodies for it but the forks are black and the Yamaha trunk rack is black so I decided to just stick with that theme. I bought black offset highway pegs and installed the Yamaha rack. I have the Yamaha black saddlebag lid protectors ordered. I never cared much for the black trim on vehicles nor even the color-coded "monochrome look that some cars used. The black on this bike is starting to grow on me though. I kind of like the departure from my usual. The only thing I'm awaiting arrival on are the handlebar risers, lid protectors, and lower wind deflectors. Kuryakyn black mesh type cup holder is ordered but is back-ordered until sometime in October. Sebel horns that were kindly sent by another member here arrived yesterday. Will look at installing one or both of them over the next few days if I ever get caught up on Stairlift installs. It has been a very busy couple of weeks for that. I had a large custom curved install last Saturday and then this week I've had and have installs every day of the week including possibly Saturday if they decide to move ahead with that one. I've had very little time to play with the bike.
dragonstorm Posted November 28, 2018 Posted November 28, 2018 The only thing I'm awaiting arrival on are the handlebar risers, lid protectors, and lower wind deflectors. Kuryakyn black mesh type cup holder is ordered but is back-ordered until sometime in October. Have you installed the lower wind deflectors yet? How difficult were they?
Freebird Posted November 28, 2018 Author Posted November 28, 2018 Yes I have. They are relatively easy to install. You have to remove he lower fairings but that is very easy. Some holes to drill but the locations are marked on the backside from the factory.
BlueSky Posted November 28, 2018 Posted November 28, 2018 Yep, the RSV trunk rack is rated for 10 lbs max load. My 07 RSV's trunk rack still has the sticker with the 10lb max load rating on it. The top to bottom "feet" on both sides of the rack are connected by a metal strip.
djh3 Posted November 29, 2018 Posted November 29, 2018 LOL 4 lb. The rack probably weighs half that. Maybe they misprinted it and its supposed to be 14lb? I think Victory's weight limit is also rite at 10lb. Pretty sure mine has met and or exceed that a time or three. However, I will say stacking stuff on the top of the trunk began to worry me some. Thats why I sprung for the hitch and the cooler rack to get that stuff low.
dragonstorm Posted December 2, 2018 Posted December 2, 2018 I have another question off the topic of this thread, but all the other bike I have purchased in the past have either had a designated place for paperwork (insurance card, registration, etc) or there was a decent place to store it. I have yet to find one such place on this bike. So the question is, where are you, the SVTC owners, keeping your paperwork?
ChiefGunner Posted December 2, 2018 Posted December 2, 2018 I have another question off the topic of this thread, but all the other bike I have purchased in the past have either had a designated place for paperwork (insurance card, registration, etc) or there was a decent place to store it. I have yet to find one such place on this bike. So the question is, where are you, the SVTC owners, keeping your paperwork? I have one of those bi-fold holders on the inside top of the trunk using velcro. It’s out of the way and works fine.
dragonstorm Posted December 2, 2018 Posted December 2, 2018 Ah, ok, well that will work . . . thank you again . . . was able to get my nav set up finally just used a 4th thumb drive . .. but it worked. Thanks for your reply.
ChiefGunner Posted December 2, 2018 Posted December 2, 2018 Ah, ok, well that will work . . . thank you again . . . was able to get my nav set up finally just used a 4th thumb drive . .. but it worked. Thanks for your reply. Excellent! There are some big updates for the SVTC coming soon! ENJOY!
dunkins1 Posted August 15, 2023 Posted August 15, 2023 Does anyone know what paint is used for the Yamaha stock trunk rack? Mine has a chip, it would be nice to be able to touch it up.
Marcarl Posted August 15, 2023 Posted August 15, 2023 9 hours ago, dunkins1 said: Does anyone know what paint is used for the Yamaha stock trunk rack? Mine has a chip, it would be nice to be able to touch it up. Starting a new thread might get you more replies.
