Need to replace the hoses coming off of the carburetor joints (intake). The hose that you have to remove when doing a carb sync. It is hard for me to tell for sure in all the parts illustrations, but it appears to be part number 90445-090G9-00. Just wondering if someone can confirm before I order the part. 2009 RSV.
Part #53 below from AIS parts page:
Looks to me to be just an ordinary piece of vacuum line, nothing special I wouldn't think.
Probably not, but the one on mine now was baked on pretty hard. Had to cut about 1/2" off of each one of them and took a while to clean all the stuck rubber off of the little metal tubes. So figured I would replace with hose from momma Yamaha.
Generally there is enough length to do just as you did without any adverse effect, and unless there is a pinching possibility I would just insert a normal vacuum line. You'll pay big bucks for a OEM formed line.
