Dano Posted May 10, 2008 Share #26 Posted May 10, 2008 Oh, come on BJ, the wife will be proud you got the bike fixed, the neighbors won't mind!! Rev it up a little and see how it's working! Glad everything is working now. Dan Link to comment Share on other sites More sharing options...
BJB Posted May 10, 2008 Author Share #27 Posted May 10, 2008 (edited) Oh, i forgot to mention. There is a Wire insider the Center Bolt on the Crank. Don't forget to put it in before mouting the Stator Cover. This is the Stator 'Cooler Element'. The early Bikes didn't have had this Wire, and got the Stator fried soon. There was a Factory Recall on this Issue. There was no such wire in my 89. I looked at a parts schematic online and it shows a wire. However, if it fits into the end of the crank it must be very fine because there is only a very fine hole there. Not sure something that fine would do any good? Edited May 10, 2008 by BJB added more info Link to comment Share on other sites More sharing options...
Squeeze Posted May 10, 2008 Share #28 Posted May 10, 2008 There was no such wire in my 89. I looked at a parts schematic online and it shows a wire. However, if it fits into the end of the crank it must be very fine because there is only a very fine hole there. Not sure something that fine would do any good? I recently opened 2 Engines and they didn't have that Wire either.. I was astonished first, but then ... Oh well, it's a Yammi Thing. Link to comment Share on other sites More sharing options...
Rocket Posted May 10, 2008 Share #29 Posted May 10, 2008 There was no such wire in my 89. I looked at a parts schematic online and it shows a wire. However, if it fits into the end of the crank it must be very fine because there is only a very fine hole there. Not sure something that fine would do any good? From my understanding, it keeps the hole in the bolt from plugging up, read the section on cooling kit, there is a diagram on the 2nd page. I recently opened 2 Engines and they didn't have that Wire either.. I was astonished first, but then ... Oh well, it's a Yammi Thing. Maybe removed by previous owners, not knowing its purpose???? Link to comment Share on other sites More sharing options...
Squeeze Posted May 10, 2008 Share #30 Posted May 10, 2008 .... Maybe removed by previous owners, not knowing its purpose???? Well, i got it mixed up. The Wire is INSIDE the the Rotor Bolt. Since BJ only changed the Stator, he doesn't need to undo this Bolt and therefore, no Wire shows up. The Bolt has to be dismounted when the Starter Clutch Assembly comes to a change. I'm sorry for causing some Confusion. Link to comment Share on other sites More sharing options...
Dano Posted May 10, 2008 Share #31 Posted May 10, 2008 I'm sorry for causing some Confusion. Hey, everybody rejoice! We finally got Squeeze on sumthin he didn't know!!! Ah well, I knew it couldn't last forever!! Dan Link to comment Share on other sites More sharing options...
Squeeze Posted May 10, 2008 Share #32 Posted May 10, 2008 Hey, everybody rejoice! We finally got Squeeze on sumthin he didn't know!!! Ah well, I knew it couldn't last forever!! Dan Yes Dan, that's a STRIKE !!! You could have catched me on the wrong Foot way earlier, just, you didn't ask the right Questions ... :innocent-emoticon::innocent-emoticon: (btw, came home from the first Test Ride just an Hour ago, not too bad Result on that and the Clutch on the Max is done also) Link to comment Share on other sites More sharing options...
rhncue Posted May 11, 2008 Share #33 Posted May 11, 2008 Well, i got it mixed up. The Wire is INSIDE the the Rotor Bolt. Since BJ only changed the Stator, he doesn't need to undo this Bolt and therefore, no Wire shows up. The Bolt has to be dismounted when the Starter Clutch Assembly comes to a change. I'm sorry for causing some Confusion. Actually, this wire wasn't in the bikes in the beginning. The stators started to overheat and burn up so Yamaha started putting these in and offering them for the earlier models. I bought one on e-bay one time for my bike, an 83. Without the wire the upper part of the stator gets no cooling oil run over it so that's where they overheat and then short. Dick Link to comment Share on other sites More sharing options...
