Bob K. Posted September 3, 2018 #1 Posted September 3, 2018 (edited) Here are the existing tools and hardware I had that I was able to put together for holding the fork damper rod. The 15/16" nut fit into the top of the damper rod quite nicely. The longer bolt and two nuts (versus one) were enough to fill up the socket and still be long enough to fit into the damper rod head. Hand-tightening the nuts is fine for installing and tightening the damper rod bolt. To keep the nuts from coming loose while removing the damper rod bolt, I hammered them onto the bolt with an air hammer. The Craftsman 15/16" socket walls were thin enough to fit inside of the inner fork tube. I put enough extensions together to reach to the damper rod. Once I was done tightening the damper rod bolt, I retrieved the bolt/nut tool with a magnet or just dumped it out. Edited September 4, 2018 by Bob K.
