Patmac6075 Posted August 12, 2018 Posted August 12, 2018 As the title states, can someone let me know the correct size to order for copper brake crush washers? These would be for my ‘84 VR.
cimmer Posted August 13, 2018 Posted August 13, 2018 I dont think there is anything special about the copper brake hose washers and you most likely could get them from a local parts store. Take an old one with you to match it up and you should be set. Rick F.
Prairiehammer Posted August 13, 2018 Posted August 13, 2018 (edited) You can reuse the old washers IF you anneal them (heat to red and quench) or you can find them cheap in quantity at McMaster Carr or go to your local stealer or the local auto parts store. Check out this thread: https://www.venturerider.org/forum/showthread.php?59155-Copper-crush-washer-alternate-source-for-brakes-1st-amp-2nd-gens Edited August 14, 2018 by Prairiehammer
