johnnyroid Posted July 25, 2018 Posted July 25, 2018 I know there are threads in other areas, but has anyone modded their SVTC with flashing LED brake lights? I ride with large groups regularly, and the difference between the Harley's I've seen with them next to other bikes without is very real. Was just wondering if somebody had already done the research and the work. Thanks in advance for any ideas.
wrscomncents Posted July 25, 2018 Posted July 25, 2018 I know there are threads in other areas, but has anyone modded their SVTC with flashing LED brake lights? I ride with large groups regularly, and the difference between the Harley's I've seen with them next to other bikes without is very real. Was just wondering if somebody had already done the research and the work. Thanks in advance for any ideas. This worked well for me. https://www.amazon.com/dp/B00I4J35HY/ref=cm_sw_r_cp_apa_Hi7pBbXH1GQ45
johnnyroid Posted July 25, 2018 Author Posted July 25, 2018 This worked well for me. https://www.amazon.com/dp/B00I4J35HY/ref=cm_sw_r_cp_apa_Hi7pBbXH1GQ45 Well that seems pretty easy, thanks! I'm going to grab one. Do you mind sharing how yours is hooked up?
wrscomncents Posted July 25, 2018 Posted July 25, 2018 Well that seems pretty easy, thanks! I'm going to grab one. Do you mind sharing how yours is hooked up? Really simple. Red and black wire from power source to in side and red and black wire to light from out side. Check a little on the site and see if you can find it shipped from U.S. Some may ship from China which will take a little longer to get.
wrscomncents Posted July 25, 2018 Posted July 25, 2018 Well that seems pretty easy, thanks! I'm going to grab one. Do you mind sharing how yours is hooked up? johnnyroid Check this out if you are a prime member. Also a video showing how it works in the reviews. https://www.amazon.com/Qiorange-Strobe-Controller-Flasher-Module/dp/B015QQ6YUC/ref=pd_sim_60_8?_encoding=UTF8&pd_rd_i=B015QQ6YUC&pd_rd_r=e6be8f2b-9033-11e8-8fff-2122c0dbd284&pd_rd_w=Yln1J&pd_rd_wg=cPXzh&pf_rd_i=desktop-dp-sims&pf_rd_m=ATVPDKIKX0DER&pf_rd_p=2610440344683357453&pf_rd_r=YH6D235RTB615GC9HMF5&pf_rd_s=desktop-dp-sims&pf_rd_t=40701&psc=1&refRID=YH6D235RTB615GC9HMF5
Rafterd Posted July 26, 2018 Posted July 26, 2018 This is the one I used. Works great. Looks like the one mentioned above. https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F191928974386
johnnyroid Posted August 22, 2018 Author Posted August 22, 2018 So based on the input I got here, I went with this: (https://www.amazon.com/gp/product/B00I4J35HY/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1), but can't decide on where I want or should splice it in. I'm very hesitant to make mods this early in the game, and just want to do it right the first time. My dealer says there are no warranty issues with this, but was hoping to draw from the experience of the group here before I dove in. Thanks for your time!! John
M61A1MECH Posted August 22, 2018 Posted August 22, 2018 If you do tap in to the wiring please use these types of taps, http://www.cycleterminal.com/posi-lock-connectors.html. Those wretched Scotch-lok blue crimp on pieces of **** should never be used in my opinion.
ChiefGunner Posted August 22, 2018 Posted August 22, 2018 So based on the input I got here, I went with this: ( https://www.amazon.com/gp/product/B00I4J35HY/ref=oh_aui_detailpage_o08_s00?ie=UTF8&psc=1), but can't decide on where I want or should splice it in. I'm very hesitant to make mods this early in the game, and just want to do it right the first time. My dealer says there are no warranty issues with this, but was hoping to draw from the experience of the group here before I dove in. Thanks for your time!! John BEFORE you dive in on that particular module, you might wanna consider this one! Not only does it have selectable flash modes for your brake light, it also converts your saddle bad lights into brake lights as well yet maintains turn signal functions even when brakes are applied. It’s what I did with mine. https://www.jpcycles.com/product/632-168/custom-dynamics-universal-smart-triple-play-run-brake-and-turn-signal-conversion-kit
