My 2008 RSV came with a aftermarket driving (passing lights.)
does anyone happen to know if there is a LED replacement that will fit in the same
enclosure.
thank you
enclosure.
thank you
Are they 4.5 inch lenses. If so there are many out there. I got mine from Larsen Lights. They have the seven LEDs with six in a circle around the center one and they really light the road. Get the traphazoydal spot.
:farmer:
If they are the standard sized jobs @ 4.5" they are a PAR 36 bulb I think is what they call them. So any bulb LED or incandesant will work. Some have used the LED work lights from Northern Tool
I replaced my PAR 36 driving/fog/passing lights whatever one calls them with Truck Lites. I believe they are the 81260. They are great at lighting up the road. These are more of a flood than a spot. So the sides of the road are lit up better. They draw about half the power of the PAR 36 but much brighter and whiter.
