Arxvz1200 Posted May 31, 2018 #1 Posted May 31, 2018 I have oil pan seal leaking. What is the minimum/easiest way to change the seal ? Thanks, Anssi
Arxvz1200 Posted May 31, 2018 Author #3 Posted May 31, 2018 Xvz 1200 from 84. Wasn't easy spot the leak, but finally got it.
Marcarl Posted May 31, 2018 #4 Posted May 31, 2018 Then I suggest to take the motor out to do it, you can fix the 2nd gear problem while your there anyways.
Arxvz1200 Posted June 1, 2018 Author #5 Posted June 1, 2018 Thanks. Not bad idea, but I've already have had that fixed.
snyper316 Posted June 1, 2018 #6 Posted June 1, 2018 Marcarl said: Then I suggest to take the motor out to do it, you can fix the 2nd gear problem while your there anyways. Whaaattttt? I took down exhaust to get mine easy peasy. Why need to take motor out?
Arxvz1200 Posted June 1, 2018 Author #7 Posted June 1, 2018 (edited) So snyper316 can you give me tips? A Edited June 1, 2018 by Arxvz1200
