Guest DREBBIN Posted February 1, 2007 #1 Posted February 1, 2007 How in the name of all that is holy do I get an air hose onto the front tire valve ? My compressor has the long stem which cannot fit -- I'm buying a air gauge with a 45 degree head -- I'm betting one of the companies sells an adapter for the hose too ? Thnx, DREBBIN
BuddyRich Posted February 1, 2007 #2 Posted February 1, 2007 Local auto zone has the small 45 degree heads for your air hose
Guest DREBBIN Posted February 1, 2007 #3 Posted February 1, 2007 That's was one of my stops tomorrow -- good to know such a thing exists there -- MANY thnx, DREBBIN Local auto zone has the small 45 degree heads for your air hose
Gary N. Posted February 2, 2007 #4 Posted February 2, 2007 I use one similar to this and it works very well. http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=41891
Monsta Posted February 2, 2007 #5 Posted February 2, 2007 Now when you change your front tire put a new stem on with a 90 degree angle....like the rear.
Guest Ken8143 Posted February 2, 2007 #6 Posted February 2, 2007 Hey Monsta, love the colors on your map!
Monsta Posted February 2, 2007 #7 Posted February 2, 2007 I can't wait to go to Alaska! That'll be quite a special trip!
StuD Posted February 2, 2007 #8 Posted February 2, 2007 I can't wait to go to Alaska! That'll be quite a special trip! Are you going to be able to travel through CANADA so there is a little colour north of the 49th????? :canada:
dray Posted February 2, 2007 #9 Posted February 2, 2007 if you drive it right in to auto zone they will let you try it to make sure its what you want:thumbsup2:
Monsta Posted February 2, 2007 #10 Posted February 2, 2007 Are you going to be able to travel through CANADA so there is a little colour north of the 49th????? :canada: Well...I've been to Nova Scotia and Niagra Falls. Wonder if I should add some "up North" stuff to my "list".
