Chaharly Posted May 15, 2018 #1 Posted May 15, 2018 Hey guys was cruising along when my radio just popped and shut off. I threw in my spare and it didn't turn on either so I went looking for fuses. Which fuse is the one that goes to the radio? I didn't see one labled radio and the ACC fuse was fine?
snyper316 Posted May 15, 2018 #2 Posted May 15, 2018 Hey guys was cruising along when my radio just popped and shut off. I threw in my spare and it didn't turn on either so I went looking for fuses. Which fuse is the one that goes to the radio? I didn't see one labled radio and the ACC fuse was fine? Have you switched from your glass tubes? Mine is the one of the two closest to you if you was sitting on the bike.
Chaharly Posted May 15, 2018 Author #3 Posted May 15, 2018 Have you switched from your glass tubes? Mine is the one of the two closest to you if you was sitting on the bike. All my fuses were good. I'll have to get the volt meter out after I get back from the funeral tomorrow. More than likely gonna need a new amplifier. As an update on the clutch I just went ahead and ordered a master cylinder rebuild kit and will install it this week
Air Ready Auto Posted May 15, 2018 #4 Posted May 15, 2018 Lost the ground connection? May be time to wire trace.
Prairiehammer Posted May 15, 2018 #5 Posted May 15, 2018 Hey guys was cruising along when my radio just popped and shut off. I threw in my spare and it didn't turn on either so I went looking for fuses. Which fuse is the one that goes to the radio? I didn't see one labled radio and the ACC fuse was fine? The radio fuse is located in the auxiliary fuse block.
videoarizona Posted May 15, 2018 #6 Posted May 15, 2018 Geesh. Kevin. Wish my fuse block looked as good as yours!!
Chaharly Posted May 16, 2018 Author #7 Posted May 16, 2018 After @Prairiehammer showed me that little fuse box I found the fuse and that was the problem. I almost didn't look for the fuser though, because even with it popped I was getting 12 Volts at the red wire going into the amp
Chaharly Posted May 16, 2018 Author #8 Posted May 16, 2018 The radio fuse is located in the auxiliary fuse block. http://www.venturerider.org/forum/attachment.php?attachmentid=112551 I'll be removing the glass fuse panel soon as well. One of the holders is busted away from the plastic case
