Is there a Genuine Yamaha Clutch Slave Cylinder Rebuild Kit? I can't find a part number for one anywhere. There are several after market kits on amazon and fleabay but no Yamaha kits.
Yeah, Partzilla has the slave cylinder for $84.25. I was hoping to get a rebuild kit rather than a new cylinder, but I want OEM Yamaha parts if possible.
Why get a kit when the new ones are almost as cheap....?
[TABLE=width: 100%]
[TR]
[TD=width: 60%][TABLE=width: 100%]
[TR]
[TD]1FK-16381-11-00 PUSH LEVER COMP. (Yamaha Motor) $84.25[/TD]
[/TR]
[TR]
[TD][TABLE=width: 100%]
[TR]
[TD=width: 60%]Shipped Thursday, February 15, 2018[/TD]
[TD=width: 40%]1Z1YF720YW18377956[/TD]
[/TR]
[/TABLE]
[/TD]
[/TR]
[/TABLE]
[/TD]
[TD=width: 10%]1[/TD]
[TD=width: 20%]$84.25
[/TD]
[/TR]
[/TABLE]
From Boats.net So now you have more than one choice...
Considering I found an OEM rear brake MC rebuild kit, NOS for $30.00 delivered, I'd hoped to have the same luck with the clutch slave kit.
I need a new rain suit anyway so I'll probably just order a new slave, the side cover gasket, bolt seal and Frog Toggs from Partzilla to get the free shipping.
See Honey, I saved money!
Of course this all assuming I am leaking from the slave and not from one of the rubber hydraulic hoses. I'll have to do a deep dive, seek and destroy inspection when the rain clears up to be sure.
If you look at the 89 VR clutch fiche you will see they do sell a kit to rebuild the clutch slave..
https://www.partzilla.com/catalog/yamaha/motorcycle/1989/venture-royale-xvz13dw/clutch
It is item 30. This is what I used to rebuild my 89s clutch slave a number of years ago and it hasnt leaked yet.
[TABLE=class: table table-hover table-striped table-responsive]
[TR]
[TD]30[/TD]
[TD]PUSH LEVER SEAL KIT
26H-W0098-00-00 [/TD]
[TD] $34.99
$23.13
[/TD]
[/TR]
[/TABLE]
Checking the part number on the clutch slave replacement, they are the same for the 83 and 89.
Hope this helps you out..
Rick F.
