ZOEYDOG Posted April 15, 2018 Posted April 15, 2018 Does anyone know does bike have to be moving for brake lights to work sitting idling and not driving brake lights will not come on signals work and 4 ways work. Any ideas or is it bad to the shop
cecdoo Posted April 15, 2018 Posted April 15, 2018 On all the bikes I have owned, the brake lites work when the bike is sitting still and the brakes are applied. Thats how they inspect them here in Pa. Should lite when front or rear brakes are applied. Mite want to check the fuses. Craig
ZOEYDOG Posted April 15, 2018 Author Posted April 15, 2018 On all the bikes I have owned, the brake lites work when the bike is sitting still and the brakes are applied. Thats how they inspect them here in Pa. Should lite when front or rear brakes are applied. Mite want to check the fuses. Craig Back to dealer tommrow was going to go for my first ride but no brake lights no ride
ZOEYDOG Posted April 15, 2018 Author Posted April 15, 2018 Back to dealer tommrow was going to go for my first ride but no brake lights no ride Got it fixed was just the brake light switch needed adjustment they must not have caught it at the factory or dealer. Now tommorrow first ride on the Venture.
djh3 Posted April 16, 2018 Posted April 16, 2018 Glad you figured it out. Most brake light switches are mechanically activated. Some the pedal engages the switch and some have a linkage that pulls the switch to on. I have seen a couple on cars that were in line and pressure activated. Another reason you need to be a little mechanically inclined to ride. No guaranty the mechanic doing the work was 100% although thats what we are paying for.
ZOEYDOG Posted April 16, 2018 Author Posted April 16, 2018 Glad you figured it out. Most brake light switches are mechanically activated. Some the pedal engages the switch and some have a linkage that pulls the switch to on. I have seen a couple on cars that were in line and pressure activated. Another reason you need to be a little mechanically inclined to ride. No guaranty the mechanic doing the work was 100% although thats what we are paying for. It has a pull switch was pondering what it could be then thought of the switch surprised it was never pickup on was glad I had my wife check the back I am always checking lights and oil and tire pressure before riding.
ChiefGunner Posted April 17, 2018 Posted April 17, 2018 I’m working on a different issue. I noticed that the rear bag lights only function as turn signal. I’m looking into a proper modification that will also allow them to function as brake lights for better visibility.
ChiefGunner Posted April 17, 2018 Posted April 17, 2018 I also noticed that the infotainment system actually has tie ins for a BACKUP camera installation. Was on the phone with Yamaha Customer Service & ordered a manual for the bike so I can get the proper tie ins to make that happen. Found an excellent mini camera that mounts on license plate frame and is very unobtrusive & stealthy. Will let you know how it goes!
ChiefGunner Posted April 27, 2018 Posted April 27, 2018 How fast do those things go in reverse? Very funny Karaboo! It’s to be able to easily see how your rig is towing without turning around. Side views only give you a partial. Also, she’s a BIG girl and backing her ina tight spot can be tense. It’s hard to see her butt and a camera, especially with IR for night takes all the worry out of it with a clear view.
johnnyroid Posted August 22, 2018 Posted August 22, 2018 Very funny Karaboo! It’s to be able to easily see how your rig is towing without turning around. Side views only give you a partial. Also, she’s a BIG girl and backing her ina tight spot can be tense. It’s hard to see her butt and a camera, especially with IR for night takes all the worry out of it with a clear view. I would be careful with the towing. Saw some other posts around with folks looking for hitches and stuff. Digging through the manual, it specifically states that this bike is not engineered for towing anything, and is probably not encouraged, especially warranty wise. Just putting that out there....
Freebird Posted August 22, 2018 Posted August 22, 2018 I think that nearly every bike out there has similar things in the manual. A lot of us still do it though. I guess there are some instances where it could affect your warranty but they have to PROVE that towing caused the issue. I guess I'm a bit stubborn, on any vehicle I own, I use it the way that I want to and need to. If I ever have a problem, I'll fight the battle.
M61A1MECH Posted August 22, 2018 Posted August 22, 2018 I’m working on a different issue. I noticed that the rear bag lights only function as turn signal. I’m looking into a proper modification that will also allow them to function as brake lights for better visibility. So just wondering how you made out with this idea? One problem you may run into is what I ran into when I first started building light bars for the2nd Gen Ventures. I used the same 4 LEDs on either side of the center LED as brake and turn signals, problem was if you held the brake lever back or used the foot pedal the brake the lights stayed on constant, the brake did not allow the LEDs to go out when the turn signal cycled. I tried to compensate for that by adding some dropping resistors in the brake circuit just before the LED light bar, that way you still got the brake signal to the light bar but at slightly less than full brightness, when the brakes and turns were both applied the affected 4 LEDs would cycle from full bright (turn signal power on) to reduced brightness (brake power applied) so there was still a turn indication working.
ChiefGunner Posted August 22, 2018 Posted August 22, 2018 (edited) I would be careful with the towing. Saw some other posts around with folks looking for hitches and stuff. Digging through the manual, it specifically states that this bike is not engineered for towing anything, and is probably not encouraged, especially warranty wise. Just putting that out there.... Every single bike manufacturer makes the same statement. It’s a liability thing, but Wings, HD, Stars, Shadows, Ventures, Valkyrie’s etc... have been towing for a few decades. i don’t recommend it for a novice rider, but most people riding a bike big enough to tow aren’t usually novice riders either. Edited August 22, 2018 by ChiefGunner
ChiefGunner Posted August 22, 2018 Posted August 22, 2018 (edited) So just wondering how you made out with this idea? One problem you may run into is what I ran into when I first started building light bars for the2nd Gen Ventures. I used the same 4 LEDs on either side of the center LED as brake and turn signals, problem was if you held the brake lever back or used the foot pedal the brake the lights stayed on constant, the brake did not allow the LEDs to go out when the turn signal cycled. I tried to compensate for that by adding some dropping resistors in the brake circuit just before the LED light bar, that way you still got the brake signal to the light bar but at slightly less than full brightness, when the brakes and turns were both applied the affected 4 LEDs would cycle from full bright (turn signal power on) to reduced brightness (brake power applied) so there was still a turn indication working. I like doing my research so I don’t have to “re-invent” the wheel. This is the best item I’ve found to do what we want with the rear lighting. I like the fact too that it has a number of selectable patterns you can choose from to even further personalize it. https://www.jpcycles.com/product/632-168/custom-dynamics-universal-smart-triple-play-run-brake-and-turn-signal-conversion-kit Edited August 22, 2018 by ChiefGunner Spelling
M61A1MECH Posted August 22, 2018 Posted August 22, 2018 That should work nicely, and they are using POSI-LOC products to make the connections.
ChiefGunner Posted August 23, 2018 Posted August 23, 2018 That should work nicely, and they are using POSI-LOC products to make the connections. Yes Sir, they do! Kinda indicates the “quality” right of the bat.
ecbaatz Posted October 23, 2019 Posted October 23, 2019 (edited) I like doing my research so I don’t have to “re-invent” the wheel. This is the best item I’ve found to do what we want with the rear lighting. I like the fact too that it has a number of selectable patterns you can choose from to even further personalize it. https://www.jpcycles.com/product/632-168/custom-dynamics-universal-smart-triple-play-run-brake-and-turn-signal-conversion-kit Take pictures of the install. Should be interesting results. Edited October 23, 2019 by ecbaatz
