Freebird Posted February 1, 2007 #1 Posted February 1, 2007 (edited) Thanks to Bikenut for this excellent information. Here is a list of replacement U-joints for the drive shaft on the 1st Gen Ventures. I have been running the B110 datson u-joint on my trike kit and it works great. Here is the list 1966 thru 1973 B110 Datson Car parts store Trw 20128 Spicer 5-1500X AEC 1064 Precision 392 Keith Yedica Bikenut Casco,Wisconsin Before you go this route, please read the next post. Edited October 5, 2018 by Marcarl More info
Marcarl Posted October 5, 2018 #2 Posted October 5, 2018 Freebird, Marcarl and/or to anyone else who can help with this... Couple months ago, before heading out on our emergency call to go see our new grandson,,, I ripped Tweeksis apart to install a new U-Joint.. Not wanting to pay the big $$ to Mom Yam, I ordered off the cross reference found here: https://www.venturerider.org/forum/s...ross-Reference I could not find a supplier of the TRW 20128 (Datsun?) so I went with the Spicer 5-1500x,, that one came in and had no lock ring grooves but had the top clips = my 1st Gens have to use the lower clips = reordered the Moog (Precision) 392. I knew the 392's were greasable thru the caps but figured I would grease it - pull the zerk and plug the hole if I had to. Found out that the 392's and the 5-1500x (I see Spicer does make the 5-1500 with lower clips,, looks like I just got the top clipped ones by chance) are lower clip groove ground at 1.496 inches of yoke space (see "G1" on spec sheet found here: https://www.northerndrivetrain.com/p...I-5-1500X.html ).. 1.496 inch = 38mm and our/my 1st Gen yokes require 40mm clip to clip space.. I ended up shimming out to 40mm with washers on top of the cap journals to make the 392 work (took my calipers down to ACE hardware and purchased 4 - 1mm thick x 10mm in diameter stainless flat washers @10 cents each and used them as shims inside of the caps and on top of the journals).. Thankfully the cap diameters on both the 5-1500's and the 392's do spec exactly the same as the OEM! I have replaced many U-Joints thru the years and the "feel" of the finished product was good after pressing in the caps with the vice and have now got a few miles on Tweeks with this make shift u-joint in place.. The 392 was an 8 dollar part shipped to my door and, being a person who LOVES the challenge of making things work that normally would not work - I would do it all again the same way I did BUT = it might not be a bad idea for the clubs sake to have some form of a disclaimer placed in that tech article so if one of these lop eared varmints gets stranded and needs a quick fix,,, they will know what they are up against.. Originally posted by Cowpuc.
Prairiehammer Posted October 8, 2018 #3 Posted October 8, 2018 An alternative to sourcing U-joint components for the XVZ12/XVZ13 (ALL XVZ as well as most Yamaha shaft drive vehicles): Spider: 2HR-46187-00 Bearing cups: 93399-99926-00 Circlips: 93440-20088-00 This entire assembly is available from several non-Yamaha sources. Usually listed for ATVs. Do a search for 2HR-46187-00. Kimpex part number158267. Sells for $20 or less. For instance: https://www.mfgsupply.com/atv/atvsusp/atvsuspyam/atvsuspyamujoints/19-1003-ref4-atv-rear-drive-shaft-engine-side-u-joint.html http://iowamotorparts.com/yamaha_atv_u-joints.htm https://www.kimpex.com/en-us/products/atv/suspensions-and-parts/universal-joints/kimpex-yamaha-u-joint
