Sylvester Posted April 5, 2018 Posted April 5, 2018 I have used Dunlop D404s for near 200,000 miles on my ride and had no problems. Always use Dyna Beads for balance and mount my own tires, but I have read many posts on the 777, and I thought I would try these (since they come in White Walls). I am not looking for high mileage (ran D404s for years) but I like the "sticky" part of the posts. I have a tire changer and lift so changing is quick, no spoons for me. I read that some feel that running the 130 front made it handle easier, but are these stock configured Ventures? I have lifted the rear many years back to perform the same effect and it worked. Would lowering the front (use 130 front) on my machine throw it out of whack? I think it probably would. Just rambling on but Cowpuc's review was what sent me to Shinko. If it doesn't work out I will be heading to Michigan without Hot Dogs.
Davin Posted April 5, 2018 Posted April 5, 2018 I have used Dunlop D404s for near 200,000 miles on my ride and had no problems. Always use Dyna Beads for balance and mount my own tires, but I have read many posts on the 777, and I thought I would try these (since they come in White Walls). I am not looking for high mileage (ran D404s for years) but I like the "sticky" part of the posts. I have a tire changer and lift so changing is quick, no spoons for me. I read that some feel that running the 130 front made it handle easier, but are these stock configured Ventures? I have lifted the rear many years back to perform the same effect and it worked. Would lowering the front (use 130 front) on my machine throw it out of whack? I think it probably would. Just rambling on but Cowpuc's review was what sent me to Shinko. If it doesn't work out I will be heading to Michigan without Hot Dogs. [emoji481] There isn't much difference in the height of the tire. Check this link for comparisons. https://www.tacomaworld.com/tirecalc?tires=150-80r16-130-90r16 Sent from my SM-G950F using Tapatalk
djh3 Posted April 5, 2018 Posted April 5, 2018 I liked the Shinko. I ran the 130 up front and had lowered the forks in the front triple tree and it was fine. I would think lowering the front (so I could touch ground) and raising the rear would be the same.
garyS-NJ Posted April 6, 2018 Posted April 6, 2018 I have used Dunlop D404s for near 200,000 miles on my ride and had no problems. Always use Dyna Beads for balance and mount my own tires, but I have read many posts on the 777, and I thought I would try these (since they come in White Walls). I am not looking for high mileage (ran D404s for years) but I like the "sticky" part of the posts. I have a tire changer and lift so changing is quick, no spoons for me. I read that some feel that running the 130 front made it handle easier, but are these stock configured Ventures? I have lifted the rear many years back to perform the same effect and it worked. Would lowering the front (use 130 front) on my machine throw it out of whack? I think it probably would. Just rambling on but Cowpuc's review was what sent me to Shinko. If it doesn't work out I will be heading to Michigan without Hot Dogs. [emoji481] I put 777's on my xvz12 Sent from my VS987 using Tapatalk
garyS-NJ Posted April 6, 2018 Posted April 6, 2018 I put 777's on my xvz12 Sent from my VS987 using TapatalkAnd somebody asked why I didn't put on the 230's instead and I couldn't remember.. Either it was the load rating, the expected life, or wanting a better rain tire.. Sent from my VS987 using Tapatalk
Leland Posted April 6, 2018 Posted April 6, 2018 According to Shinko's website, the smaller 130/90/16 is a 73 load weight which is 805#. Their 150/80/16 is a 71 which equals 761#. Makes no sense to me. I also run the smaller (Michelin) front tire with the front forks raised about 3/8" with no problem. I too will be trying these Shinkos next time.
Sylvester Posted April 7, 2018 Author Posted April 7, 2018 J&P Cycle said they shipped Friday and will arrive Monday. That is fast.
Sylvester Posted April 10, 2018 Author Posted April 10, 2018 They did come yesterday and like any kid (72 years old) I cut the plastic to looky see. Very nice tread design and white walls are impressive even though I have had white walls for fifteen years. And, and, and they are the freshest tires I have ever received. The front is 49/17 and the rear 01/18. I will mount them this week and give them a 100+ mile break-in.
