Broview S5 LED H4 headlight bulb no longer available... whats the newst one?
This was nice because it had a heatsink instead of a fan.
Does anyone know what the newer replacement would be? I guess iyt doesn't have to be Brovoew ... but plug and play is a priority unless I'm being real dense.
Thanks to all as always
Mike
You might look into a newer Broview.... With the S designation. If it has the proper low beam cut off, and has similar or better specs, and about same size, you might try that. Ebay search.
