sleepy2 Posted March 8, 2018 #1 Posted March 8, 2018 Can't seem to find anything to rotate the pictures but THANKS Carl for your help in turning down my bar weights down to fit inside my new Kurriakin hand grips!!!!!!!!!!
Marcarl Posted March 8, 2018 #3 Posted March 8, 2018 Thanks Sleepy, it was a good day and it all seemed to work out. Got lucky again! And you're welcome anytime. Glad you took at least 3 good pictures.
bongobobny Posted March 9, 2018 #4 Posted March 9, 2018 Wish I could have been there to see exactly how Carl did it! I was going to bore out the caps on the grips and find the right sized nut but opted for just buying the Kuryakin weights...
Freebird Posted March 9, 2018 #5 Posted March 9, 2018 I did a write-up years ago on how I installed the weights onto my Flanders bars. Not with Kuryakyn grips though. I have the KuryAkyn grips on the '05 and also went with their weights. http://www.venturerider.org/forum/showthread.php?11122-Installing-weights-on-Flanders-bars
sleepy2 Posted March 9, 2018 Author #6 Posted March 9, 2018 Thanks Kretz for turning them around. Carl used step drill to cut the end hole(of the grips) out to the thread size of the weights then turned down roughly 1/2 in. or so of the chromed shoulder so it could slide in and bolt up to handle bars. They look and feel great. Thanks again!! Carl also mentioned how well my bike seemed to be holding the trailer. When I got home and had my son help me take bike off my truck had every idiot light on the dash light up and started dinging. Took into dealer on Tues. and found out it could be part of the computer as the part is going to cost $900can and a total of $1300can to get it back. Had to wait till Wed. to get part in overnight but snowed in morning and 2 mechanics couldn't get to work and the tec who does this work phoned in sick so waited till Thurs. but jobs from Wed. were to go first before mine and so didn't get any where until today and just called and am waiting to find out if I get it back today
s.tyler58 Posted March 10, 2018 #7 Posted March 10, 2018 Thanks Kretz for turning them around. Carl used step drill to cut the end hole(of the grips) out to the thread size of the weights then turned down roughly 1/2 in. or so of the chromed shoulder so it could slide in and bolt up to handle bars. They look and feel great. Thanks again!! Carl also mentioned how well my bike seemed to be holding the trailer. When I got home and had my son help me take bike off my truck had every idiot light on the dash light up and started dinging. Took into dealer on Tues. and found out it could be part of the computer as the part is going to cost $900can and a total of $1300can to get it back. Had to wait till Wed. to get part in overnight but snowed in morning and 2 mechanics couldn't get to work and the tec who does this work phoned in sick so waited till Thurs. but jobs from Wed. were to go first before mine and so didn't get any where until today and just called and am waiting to find out if I get it back todayHoly smokes! That's quite a week! ...in the Eternal scheme of things, this isn't even the blink of an eye.
sleepy2 Posted March 10, 2018 Author #8 Posted March 10, 2018 Update on truck----part that failed was the main fuse-box under hood.Finally picked truck up yesterday. Had to phone them and left message--2 hours later they called to say truck was done. Went to pick up and ended up $1350can part $900+ labor + diagnostic + tax(government tax added) Got in truck to leave AND Air-bag light came on--drove around building right back into service so tech could check it out. Found out this was the second unit tried as replacement was defective. After getting new one they forgot to make sure all fuses and relays were seated in the box so ABS and Air-bag lights came on. They said instructions didn't tell them to do this?????? I think it would have been the first thing to do without being told. All in all everything seems to be all right for now. Seems the saying goes and usually applies to me If It wasn't for bad luck I wouldn't have any luck!!!!!!!!!!!!
saddlebum Posted March 11, 2018 #9 Posted March 11, 2018 Thanks Sleepy, it was a good day and it all seemed to work out. Got lucky again! And you're welcome anytime. Glad you took at least 3 good pictures. Yeh the two of the motorcycle and the one were Marcarl has his back turned to the camera P.S. One thing about Carl he is always there when help is needed.
Marcarl Posted March 11, 2018 #10 Posted March 11, 2018 Yeh the two of the motorcycle and the one were Marcarl has his back turned to the camera My first thought about your comment was: YOU!!! go sit in the lake, but actually you're almost right spot on.The 2 of the bike and the one of SleepyII.
Mover Posted May 25, 2018 #11 Posted May 25, 2018 What's the part number of the Kuryakyn ISO grips that you installed? I'd like to retain the Yamaha bar ends as well. I just received the 6345 grips (black anodized) which are for the RSV but they appear to be a fair bit longer than the stock grips. Removing the end of the ISO grips will make them a bit shorter. I'm not very mechanically inclined to am trying to obtain as much info as possible before starting the job. Thanks Mover
Marcarl Posted May 25, 2018 #12 Posted May 25, 2018 What's the part number of the Kuryakyn ISO grips that you installed? I'd like to retain the Yamaha bar ends as well. I just received the 6345 grips (black anodized) which are for the RSV but they appear to be a fair bit longer than the stock grips. Removing the end of the ISO grips will make them a bit shorter. I'm not very mechanically inclined to am trying to obtain as much info as possible before starting the job. Thanks Mover https://www.kuryakyn.com/products/33/iso-grips Had to trim the oem grips at the handlebar, other than that, nice fit, a little longer than oem.
Mover Posted May 25, 2018 #13 Posted May 25, 2018 https://www.kuryakyn.com/products/33/iso-grips Had to trim the oem grips at the handlebar, other than that, nice fit, a little longer than oem. Did the 'OEM grips' need trimming or the 'OEM bar end weights' ?
Marcarl Posted May 26, 2018 #14 Posted May 26, 2018 Did the 'OEM grips' need trimming or the 'OEM bar end weights' ? All I had to rim was the rim closest to center, the rim that keeps or is supposed to keep your hand from going up the grip too far.
sleepy2 Posted June 1, 2018 Author #15 Posted June 1, 2018 I had to take the truck in again with the same problems as before. The son used his code reader again and got the very same code as the first time . It said a module wasn't reading so dealer finally agreed they changed wrong part(fuse box first time) and would change it for free. Took it in today and got module changed and hopefully it is fixed.
saddlebum Posted June 2, 2018 #16 Posted June 2, 2018 (edited) See as how there is already a Thanks Marcarl thread guess I best throw my hat in the ring. With all the best of intentions Marcarl spent all day Thurs helping me get my machine back on the road so I could make it to MD and we almost succeeded too, despite all the issues that kept popping up, not the least being the bike falling off the lift table a few days before. It started out simple enough. Get new hides on the rims. But then there was all that oil leaking down the back of the front forks. Ok, no biggie. Just reseal the forks and with Carl there to help who has a few forks under his belt. How hard could it be? Until--------we got into it and the forks were not resealable due to some butcher (and I'm not talking about a meat cutter like Carl). OK all is not lost after some serious discussion I give into Carl,s suggestion to steal the forks off my Project bike Which I inherited from Abdul. Well eventually we got the good old girl pretty much back together at which point Carl left to put some final touches to his own machine. and i'm sure from all the hard work and the heat he was as exhausted as I was. It really was disappointing to work so hard to get that done and still not be able to go due to a sudden loss of brakes, double so that I had to Call Carl and say that after all that hard work I was still not able to go. But just the same, Thanks once again Marcarl for all your help. I really wish things worked out better. Edited June 3, 2018 by saddlebum
