GolfVenture Posted November 24, 2017 #1 Posted November 24, 2017 Any opinions on these types of wrenches? Or which ones are good ones at a good price? https://wiki-store.com/collections/house/products/amazing-grip
Du-Rron Posted November 24, 2017 #2 Posted November 24, 2017 Any opinions on these types of wrenches? Or which ones are good ones at a good price? https://wiki-store.com/collections/house/products/amazing-grip They are all trash. Too big and bulky to fit against flush heads and usually not enough swinging room to use them. They would not be my first tool of choice. Maybe pack one in the saddle bag and hope not to have to use it on anything.
djh3 Posted November 24, 2017 #3 Posted November 24, 2017 Emergency use maybe. Might be OK as an addition to a tool kit, but I wouldnt want to use as first defense in my tool box.
MikeWa Posted November 24, 2017 #4 Posted November 24, 2017 They could work for some applications. Especially if a nut is partly rounded off. Again not my first choice but they could come in handy on occasion. Mike
Great adVENTURE Posted November 24, 2017 #5 Posted November 24, 2017 If your intrested in a adjustable wrench the knipex pliar wrench is absolutely amazing! Comes in multiple sizes also. Adjust the jaws to the approximate size of the nut then squeeze. The jaws move in a parallel motion to be able to apply major torque.
Karaboo Posted November 25, 2017 #6 Posted November 25, 2017 They are pretty good at rounding off the hex, if that is what you are going for.
Air Ready Auto Posted November 25, 2017 #7 Posted November 25, 2017 If your intrested in a adjustable wrench the knipex pliar wrench is absolutely amazing! Comes in multiple sizes also. Adjust the jaws to the approximate size of the nut then squeeze. The jaws move in a parallel motion to be able to apply major torque. I have a complete Knipex set. Pricey but completely worth every penny.
CaseyJ955 Posted November 25, 2017 #8 Posted November 25, 2017 If your intrested in a adjustable wrench the knipex pliar wrench is absolutely amazing! Comes in multiple sizes also. Adjust the jaws to the approximate size of the nut then squeeze. The jaws move in a parallel motion to be able to apply major torque. Okay, this dude aint lying! I'm looking at the Amazing Grip very closely indeed and I cant say that it looks like a quality tool. I dont know but I strongly suspect it's made in China based on the visual impression of build quality and fit/finish. Most of my tools are Snap-on, Matco and MAC with a smattering of S&K and OLD craftsman. A tool must last forever and work perfectly, NOTHING less is acceptable. Many years ago I bought a Knipex Cobra after watching a 250+ lb salesman place it on a folding table cross bar, step onto it and bounce his weight as it did not budge. This is not a vice grip, its only a slip joint. I guess ya had to be there, I was deeply impressed and paid the premium for it on the spot. I have been regularly using and abusing this Knipex Cobra for over half my life and it has not lost any function or gotten even a little bit sloppy. It looks very well used, and it is, but works just as it did the day I bought it. I just looked them up on Ebay, my Cobra is an older generation, looks a little different, perhaps less attractive. If the newer ones are half as good as this old one you cant go wrong. I see 3 pc sets on ebay for about $80, it sounds expensive but for what you get it's well worth it. I just had to relay my fantastic experience with the Knipex pliar. My other slip joints are Snap-on, Blue Point, Channel lock and Craftsman and none of them can hold a candle to my Knipex. They are nice but the Knipex is a cut above. It is hands down and by quite a margin the finest built and functioning slip joint I have ever had in my hand. I give the Knipex 5 stars and I'm not easy to please when it comes to tools. Highly recommended.
luvmy40 Posted November 25, 2017 #9 Posted November 25, 2017 (edited) I'm going to have to take a look at those Knipex pliers. I have a couple different sizes of the RoboGrip pliers from Sears and like the concept. The work fairly well but do not allow the torqued that a couple of you ascribe to the Knipex tools. I picked up a set of these in SAE and one in metric. I keep the metric set in the fairing console of my Venture along with a folding set of hex keys and a 6 way combination screw driver. https://www.autozone.com/wrenches-pliers-and-cutters/wrench/duralast-2-pcs-sae-ratcheting-wrench-set/951643_0_0 https://www.autozone.com/wrenches-pliers-and-cutters/wrench/duralast-2-pcs-metric-ratcheting-wrench-set/951644_0_0 I'm sure the wrenches are available from other sources but I get the employee's discount at AZ so... Edited November 25, 2017 by luvmy40
GolfVenture Posted November 26, 2017 Author #10 Posted November 26, 2017 Thank You all. I will be looking at the Knipex Pliar Wrench.
baylensman Posted November 29, 2017 #11 Posted November 29, 2017 I've had a slip jaw wrench since the early 70's . They are not new! they come and go. Absolutely the best tool every when I was repairing bicycles and assembling swing sets.
Du-Rron Posted November 29, 2017 #12 Posted November 29, 2017 But is seems this conversation has moved away from the original question. Knipex & slip jaw wrenches were not part of the question.
GolfVenture Posted November 29, 2017 Author #13 Posted November 29, 2017 But is seems this conversation has moved away from the original question. Knipex & slip jaw wrenches were not part of the question. My question was in general. I got the answer I wanted about the Knipex. I ordered one.
CaseyJ955 Posted November 29, 2017 #14 Posted November 29, 2017 My question was in general. I got the answer I wanted about the Knipex. I ordered one. You wont be sorry, it's very well worth having in ones tool box.
