Emergency use maybe. Might be OK as an addition to a tool kit, but I wouldnt want to use as first defense in my tool box.
They could work for some applications. Especially if a nut is partly rounded off. Again not my first choice but they could come in handy on occasion.
Mike
If your intrested in a adjustable wrench the knipex pliar wrench is absolutely amazing! Comes in multiple sizes also. Adjust the jaws to the approximate size of the nut then squeeze. The jaws move in a parallel motion to be able to apply major torque.
:sign yeah that:
I have a complete Knipex set. Pricey but completely worth every penny.
Okay, this dude aint lying!
I'm looking at the Amazing Grip very closely indeed and I cant say that it looks like a quality tool. I dont know but I strongly suspect it's made in China based on the visual impression of build quality and fit/finish. Most of my tools are Snap-on, Matco and MAC with a smattering of S&K and OLD craftsman. A tool must last forever and work perfectly, NOTHING less is acceptable.
Many years ago I bought a Knipex Cobra after watching a 250+ lb salesman place it on a folding table cross bar, step onto it and bounce his weight as it did not budge. This is not a vice grip, its only a slip joint. I guess ya had to be there, I was deeply impressed and paid the premium for it on the spot. I have been regularly using and abusing this Knipex Cobra for over half my life and it has not lost any function or gotten even a little bit sloppy. It looks very well used, and it is, but works just as it did the day I bought it.
I just looked them up on Ebay, my Cobra is an older generation, looks a little different, perhaps less attractive. If the newer ones are half as good as this old one you cant go wrong. I see 3 pc sets on ebay for about $80, it sounds expensive but for what you get it's well worth it.
I just had to relay my fantastic experience with the Knipex pliar. My other slip joints are Snap-on, Blue Point, Channel lock and Craftsman and none of them can hold a candle to my Knipex. They are nice but the Knipex is a cut above. It is hands down and by quite a margin the finest built and functioning slip joint I have ever had in my hand.
I give the Knipex 5 stars and I'm not easy to please when it comes to tools. Highly recommended.
I'm going to have to take a look at those Knipex pliers. I have a couple different sizes of the RoboGrip pliers from Sears and like the concept. The work fairly well but do not allow the torqued that a couple of you ascribe to the Knipex tools.
I picked up a set of these in SAE and one in metric. I keep the metric set in the fairing console of my Venture along with a folding set of hex keys and a 6 way combination screw driver.
https://www.autozone.com/wrenches-pliers-and-cutters/wrench/duralast-2-pcs-sae-ratcheting-wrench-set/951643_0_0
https://www.autozone.com/wrenches-pliers-and-cutters/wrench/duralast-2-pcs-metric-ratcheting-wrench-set/951644_0_0
I'm sure the wrenches are available from other sources but I get the employee's discount at AZ so...
Edited by luvmy40
I've had a slip jaw wrench since the early 70's . They are not new! they come and go. Absolutely the best tool every when I was repairing bicycles and assembling swing sets.
But is seems this conversation has moved away from the original question. Knipex & slip jaw wrenches were not part of the question.
My question was in general.
I got the answer I wanted about the Knipex. I ordered one.
