GolfVenture Posted November 12, 2017 #1 Posted November 12, 2017 (edited) I'd like to talk to anyone who has owned a 92 Dodge Diesel D250. I'm changing the oil and filter for the 1st time and need some advise. I've looked on-line some and the instructions does not fit mine. call me at 206-245-8408. Mean while I will search for more instructions. Please Ignore......... Need to figure how to delete this post.... Edited November 12, 2017 by Golf&Venture none
Du-Rron Posted November 12, 2017 #2 Posted November 12, 2017 I'd like to talk to anyone who has owned a 92 Dodge Diesel D250. I'm changing the oil and filter for the 1st time and need some advise. I've looked on-line some and the instructions does not fit mine. call me at 206-245-8408. Mean while I will search for more instructions. Please Ignore......... Need to figure how to delete this post.... Thought I'd have a shot anyway. 1. Remove turbo to air-filter tube. 2. remove bolt that holds AC receiver/dryer to fender and let it drop down. 3. remove oil filter. 4. when reinstalling oil filter I recommend filling filter with new oil.
GolfVenture Posted November 13, 2017 Author #3 Posted November 13, 2017 Thought I'd have a shot anyway. 1. Remove turbo to air-filter tube. 2. remove bolt that holds AC receiver/dryer to fender and let it drop down. 3. remove oil filter. 4. when reinstalling oil filter I recommend filling filter with new oil. Tks for the reply. I have to laugh at myself. So Sat evening I took the Air-filter off Then put the correct oil filter socket on at the bottom. But I could not get the ratchet on. So I quit for it was getting dark. Next morning I went and got the old spring lever type wrench. I could not get it on at the bottom. Then I saw this fitting on at the bottom of the filter. I felt the center of this fitting and felt/though there was a hydrolic line going into the bottom of the filter. I said how can this be. I looked at the nre filter and there is no hole at th bottom of the filter. Well Maybe I got the wrong filter being that this my fitrst diesel. So I got my flash light and shined at the fitting at the bottom of the filter. Then I realized that I had left the filter scoket wrench over night. Took it and used the spring lever type of filter wrenct. Rest was a piece a cake. Was surprised that it too about 2 and 1/2 gallons of motor oil. But again thanks for replying. Brian T.
djh3 Posted November 13, 2017 #4 Posted November 13, 2017 My 96 (also a 12v cummins) takes like 11 Qt plus filter. Any of these bigger filters like the FL1 that I can stand filter up so oil dont run out I fill with oil prior to installation. It takes valuable time to pump it full with engine.
