I was looking at an LED headlight recommendation i got from here a couple of years ago and now I cannot find it again but it is probably out dated. As many might have noticed the price of an LED replacement bulb, single or duel filament (if that is what you would call it?) have come way down. I just put a pair in my Freightliner that cost less than the regular lights. I think they were around $40 for the pair.
So now that I have the bike on the stand and its getting dark out earlier I thought it was time to replace the bulb with an LED.
While I know most of the plugs and housing are somewhat standard most of the products only list what cars they are compatible.
So can anyone on here speak from experience as to an LED they purchased recently that they can recommend. I can speak for the "Nineo" brand I put in my truck. The were inexpensive, simple to put in and the company replace both of them after one went bad. I could not find a high/low beam bulb from them otherwise I would have just taken a chance. But since I need to shop I thought it wise to ask here and see what you guys might have first hand experience with.
see if this thread helps....there are others as well..
http://www.venturerider.org/forum/showthread.php?129385-1st-Gen-LED-Headlight&highlight=bulb
My bulbs I put in both of my Ventures are Broview, but with the braid for a heat sink, not a fan. Might not have enough room for a fan type bulb. Check bulb length.
Bulb was easy install, the forum gang helped me jumper the RLU and modify the computer for LED's.
