Freebird Posted August 22, 2006 Posted August 22, 2006 Brake Bleeder If you have ever gotten air in the rear brake system of a 83-85 Venture you know how tuff it is to get it out again. This is a simple fix, well maybe not that simple. In 1986-93 Ventures Yamaha fixed the problem by adding a short extension to the left front brake hose Part # 2WR-25873-01-00. The end of the hose was mounted on the top of the triple tree with a small bracket. This hose Must be ordered from Yamaha Japan . There are two other parts, NUT 95306-12600-00 & bleeder assembly Part # 1NL-W0048-00. It was $105 for the hose from Yamaha. But if you can find it in a junk yard it will be a lot cheaper and you will get all three parts. It is a little tuff to get the Banjo bolt out and back in because it attaches to the proportioning valve almost hidden under the top bar on the triple tree see Pic 01, the hose routing see Pic 02. http://www.venturerider.org/brakebleeder/image003.jpg http://www.venturerider.org/brakebleeder/image002.jpg Picture 1 Picture 2 This would be an excellent project for those winter months when you aren't riding. Fred Vogt
