sleadhed Posted April 23, 2008 Posted April 23, 2008 Have any of you installed these in the rear? I got these for the front, Now I am wondering if they will fit in the rear without modification. Have you up-graded the rears? what did you use for a speaker? Did you have to modify?
Eck Posted April 23, 2008 Posted April 23, 2008 Have any of you installed these in the rear? I got these for the front, Now I am wondering if they will fit in the rear without modification. Have you up-graded the rears? what did you use for a speaker? Did you have to modify? Page down to the bottom of this page (not this post, but the page) and you will find may posts about changing speakers ...
Guest tesnevo Posted May 18, 2008 Posted May 18, 2008 Have any of you installed these in the rear? I got these for the front, Now I am wondering if they will fit in the rear without modification. Have you up-graded the rears? what did you use for a speaker? Did you have to modify? To answer your question, yes they work and very well I might add. A few pointers though. Front speakers are a little snug as far as the holes in the speaker going onto the post, but do fit fine. I removed the protective screens off the factory speaker and put them in front of the new ones (like the old speakers had them) and re-installed. You can bend the Polk mounting holes/tabs in to make them tighten nice and snug. You will see this when you do the change out. Rears are easy too. I went ahead and ordered the new arm rest pads since it made it easier to re-install. They sound great.
