micheal Posted September 10, 2017 #1 Posted September 10, 2017 My audio system on my Venture quit working. I checked the fuse and it was good but I replaced it anyway. There doesn't appear to be power to the controller on the handlebar. Does anyone have any possible solutions?
etcswjoe Posted September 10, 2017 #2 Posted September 10, 2017 My audio system on my Venture quit working. I checked the fuse and it was good but I replaced it anyway. There doesn't appear to be power to the controller on the handlebar. Does anyone have any possible solutions?[/QU Pop the front fairing off, clean the connectors going to the radio unit, put a little dielectric grease around them, loose/dirty connectors are usually the cause of the problem.
M61A1MECH Posted September 10, 2017 #3 Posted September 10, 2017 Here is a link to our tech section , it has the Yamaha Tech Bulletin on the audio system, it may help. http://www.venturerider.org/forum/showthread.php?62016-Audio-System-Tech-Bulletin-M2008-003
Freebird Posted September 10, 2017 #4 Posted September 10, 2017 Which fuse did you check? I think there are actually two of them. One is behind the side cover on the left and the other is inside the lower cowling on the right side.
