Statussymbol Posted August 14, 2017 #1 Posted August 14, 2017 Is there any adverse effect on removing the "stop" from the rear trunk? i.e. plastic cracking at the hinge. I put my work bag in the trunk and it does not lift far enough up for me to not wedge my bag into it. Thanks Stat
Kirby Posted August 14, 2017 #2 Posted August 14, 2017 The stop linkage is bent. Just gently lift up on the lid and they will straighten back out. It should lift up to 90 degrees. Been there, done that!
XV1100SE Posted August 14, 2017 #3 Posted August 14, 2017 If the plastic is cracked, it is ABS so you can use ABS cement to repair it. Better solution is (I think it is called) plastex. Do a search for plastic repair and you'll find it. Not cheap but does a really nice repair as it bonds the plastic back together. ABS cement will dry out over time and would be 2nd choice.
AKRefugee Posted August 15, 2017 #4 Posted August 15, 2017 Is there any adverse effect on removing the "stop" from the rear trunk? i.e. plastic cracking at the hinge. I put my work bag in the trunk and it does not lift far enough up for me to not wedge my bag into it. Thanks Stat If you are talking about the arm then no there is no problem with having it removed. I haven't had one on for several years now.
djh3 Posted August 15, 2017 #5 Posted August 15, 2017 My Victory Cross Country had a cable on one side. When I added the rack I felt it added enough weight once over center it needed another cable. So I made one with a couple eyes for wiring and some 12ga wire. Just don't like the idea of the hinge being the stop.
Statussymbol Posted August 15, 2017 Author #6 Posted August 15, 2017 If you are talking about the arm then no there is no problem with having it removed. I haven't had one on for several years now. yes the arm...it seems to be binding
