I give them a little shot in each tank during riding season.
A shot of what?
I've been putting 2 ounces of MMO in each tank for about 5 months and it still got gummed up. Had to put in some Seafoam to clear it up. Just what is MMO supposed to do?
A shot of what?
lubricates the Butterfly, float needle and cleans the valves just a hair... But Yammer says he mixes seafoam and that. I buy the non ethanol gas try to run it fifty fifty, so about 7% ethanol with MMO. And a shot glass of Seafoam
Edited by snyper316
I was called Stupid for doing this. That won't happen again. I mix Marvel Mystery, Sea Foam and Berryman's Chem Tech. I mix it in about equal amounts. Works great for me. And cuts down the price of SeaFoam if you figure the long range plan. I buy the SeaFoam when they put it on sale by the gallon and now that we have a Rural King I can buy it all in the large containers which is usually a lot cheaper. Now my secrets are out!!! I use this when I know they are dirty. I use SeaFoam and Mystery Oil about equal amounts to keep them clean.
That seems to be a pretty potent mix. Perhaps the best use of MMO is to cut the potency of the Berryman's. I don't recall ever seeing Berryman's around here. See if I can find it.
So about 50/50 and how much per tank?
Berrymans does not import into Canada because they don't have a distributor here.
Couple oz. per tank if I remember it.. I keep in the bags and use it fairly often! If I remember it!!:fatsmiley:
Berrymans is available on amazon.ca for... (trumpet flourish) ... a 15 oz can... (trumpet flourish) ... $53.
Whooo Hooo!!!
