camos Posted March 13, 2018 Author #26 Posted March 13, 2018 I give them a little shot in each tank during riding season.A shot of what? I've been putting 2 ounces of MMO in each tank for about 5 months and it still got gummed up. Had to put in some Seafoam to clear it up. Just what is MMO supposed to do?
snyper316 Posted March 13, 2018 #27 Posted March 13, 2018 (edited) A shot of what? I've been putting 2 ounces of MMO in each tank for about 5 months and it still got gummed up. Had to put in some Seafoam to clear it up. Just what is MMO supposed to do? lubricates the Butterfly, float needle and cleans the valves just a hair... But Yammer says he mixes seafoam and that. I buy the non ethanol gas try to run it fifty fifty, so about 7% ethanol with MMO. And a shot glass of Seafoam Edited March 13, 2018 by snyper316
Yammer Dan Posted March 13, 2018 #28 Posted March 13, 2018 I was called Stupid for doing this. That won't happen again. I mix Marvel Mystery, Sea Foam and Berryman's Chem Tech. I mix it in about equal amounts. Works great for me. And cuts down the price of SeaFoam if you figure the long range plan. I buy the SeaFoam when they put it on sale by the gallon and now that we have a Rural King I can buy it all in the large containers which is usually a lot cheaper. Now my secrets are out!!! I use this when I know they are dirty. I use SeaFoam and Mystery Oil about equal amounts to keep them clean.
camos Posted March 13, 2018 Author #29 Posted March 13, 2018 I mix Marvel Mystery, Sea Foam and Berryman's Chem Tech. I mix it in about equal amounts.That seems to be a pretty potent mix. Perhaps the best use of MMO is to cut the potency of the Berryman's. I don't recall ever seeing Berryman's around here. See if I can find it. I use SeaFoam and Mystery Oil about equal amounts to keep them clean.So about 50/50 and how much per tank?
XV1100SE Posted March 13, 2018 #30 Posted March 13, 2018 That seems to be a pretty potent mix. Perhaps the best use of MMO is to cut the potency of the Berryman's. I don't recall ever seeing Berryman's around here. See if I can find it. Berrymans does not import into Canada because they don't have a distributor here.
Yammer Dan Posted March 13, 2018 #31 Posted March 13, 2018 That seems to be a pretty potent mix. Perhaps the best use of MMO is to cut the potency of the Berryman's. I don't recall ever seeing Berryman's around here. See if I can find it. So about 50/50 and how much per tank? Couple oz. per tank if I remember it.. I keep in the bags and use it fairly often! If I remember it!!
camos Posted March 13, 2018 Author #32 Posted March 13, 2018 Berrymans does not import into Canada because they don't have a distributor here.Berrymans is available on amazon.ca for... (trumpet flourish) ... a 15 oz can... (trumpet flourish) ... $53. Whooo Hooo!!!
Yammer Dan Posted March 14, 2018 #33 Posted March 14, 2018 BerryMans less than 4 bucks at Wally World........
camos Posted March 15, 2018 Author #34 Posted March 15, 2018 BerryMans less than 4 bucks at Wally World........I know, SAD. Who is really getting screwed by NAFTA?
