Got the dual usb and voltmeter installed. According to my readings on my dm i read .5-1volt low from actual reading at the wire that charges battery. I think it my be because where I hooked it up. Here are some pics.
This is the only modern upgrade we plan to make until radio goes out.
That's cool, like the dual purpose. I put a DVM only on my 89 in 2015. It also read .5 v low. Hooked the wires into a terminal block which was connected to the battery and it read low so I tried it connected directly to the battery and it was the same so figured it's the meter. Perhaps Chinese volts are low.
http://www.venturerider.org/forum/attachment.php?attachmentid=106392
http://www.venturerider.org/forum/attachment.php?attachmentid=106393
Had to make a wedge mount that tilted toward me to be able to see it in the sun.
