When stuck in traffic, my gauge goes almost to the red ! The fan works and my coolant is full in the radiator and overflow. Is it normal gauge goes this high? When I start rolling at higher speed , temperature drops to halfway.
Thanks
When was the last time you had the cooling system flushed?? Do you use a product called "Wetter Water?"
Yes, it may be normal, but there are things to do to minimize the effects...
Thanks
My 83 does that. Its fairly normal. Mine runs about 3/4 of the way up then hits almost red line when in the city or stop and go traffic.
Thanks
Hard to say but might be worth checking to see if the radiator is gobbed up with debris. Last time I had mine out there were quite a few insects in there.
It sure sounds normal to me if its a MK1 (thats all I really know about on these Ventures).. I will say this though,, if it is a MK1 - might not be a bad idea to remember they came with the plastic waterpump impeller.. I have replaced a couple of those plastic ones with the aluminum updates thru the years and can tell you - if I my 83 was developing a tendency to run warmer than I liked - I wouldnt hesitate to pull the pump and check it.. If its plastic they LOVE to loose the impellar fins to degradation ending up with no more than a disc to try and move the coolant thru the system.. :2cents:
