Big Auggie Posted June 28, 2017 #1 Posted June 28, 2017 I frequently get the warning light for the front master brake cylinder during acceleration or if it's sitting on it's side stand idling. I'm assuming the reservoir above the lever is not the master cylinder. So just exactly where is the front master cylinder?
Big Auggie Posted June 28, 2017 Author #2 Posted June 28, 2017 Think I found it. Behind the right back cylinder jug. Well, at least that one was low so hoping that solves the warning light problem. Time will tell!
mralex714 Posted June 28, 2017 #3 Posted June 28, 2017 I frequently get the warning light for the front master brake cylinder during acceleration or if it's sitting on it's side stand idling. I'm assuming the reservoir above the lever is not the master cylinder. So just exactly where is the front master cylinder? The master cylinder is where the handle goes into the bottom of the reservoir. BTW that light is for the front and rear. One more thing are you sure it's not the low engine oil light coming on?
Big Auggie Posted June 29, 2017 Author #4 Posted June 29, 2017 The master cylinder is where the handle goes into the bottom of the reservoir. BTW that light is for the front and rear. One more thing are you sure it's not the low engine oil light coming on? I checked the owners manual, the icon showing up is for the brake. Book says it's for the front brake master cylinder.
Big Auggie Posted June 29, 2017 Author #5 Posted June 29, 2017 Got er done. Just got back from about a 30 mile test run. No light!! Running smoooooth!
