Aussie Posted June 27, 2017 #1 Posted June 27, 2017 Howdy folks, my trip is getting closer and I'm seriously thinking about converting the 83 I bought to independent front and rear brakes. I have found an old master cylinder and front dual lines from an 83 Suzuki gs1000.. does anyone know if the banjo bolts are the same size before I pack it in the suitcase for the trip over??
Not That Guy Posted June 27, 2017 #2 Posted June 27, 2017 (edited) Caliper banjo bolts right? Reuse them with new crush washers. What will you be doing with the rear portioning valve? There's a good kit that has all the needed bits from a vendor here that I recommend. Edited June 27, 2017 by Not That Guy
