I have an original ignition module.
:farmer:
Maybe there is someone on the board that has an ignition module left over from when then put a DYNA 3K in that they would loan you to verify if it is the ignition control module or not. It could be as BongoBob said the starting circuit cutoff relay, there are about 6 diodes in there and it is possible it went bad, but that failure is rare in my recollection, as is a failed ignition module.
