mtcowboy Posted June 16, 2017 #1 Posted June 16, 2017 no air getting to the forks any imput would be appreciated.
camos Posted June 17, 2017 #2 Posted June 17, 2017 mtcowboy said: no air getting to the forks any imput would be appreciated.That's pretty open ended but to begin with: Any leaks in the hoses that connect at the forks? Leaks around the collars where those hoses connect? Leaks at the fork seals? Then there is: Does the compressor turn on? Does the rear air up?
cimmer Posted June 17, 2017 #3 Posted June 17, 2017 Another thought is that the air compressor only works when the ignition key is in the acc position and not the on position. Just throwing it out there in case you didnt know that.. Rick F.
mtcowboy Posted June 23, 2017 Author #4 Posted June 23, 2017 camos said: That's pretty open ended but to begin with: Any leaks in the hoses that connect at the forks? Leaks around the collars where those hoses connect? Leaks at the fork seals? Then there is: Does the compressor turn on? Does the rear air up? Replaced fork seals and bought new compressor found leak in the air line from fork to fork. hope it works bought a used airline to try. is there away to plug off air to front and put good shocks on the front?
videoarizona Posted June 23, 2017 #6 Posted June 23, 2017 mtcowboy said: Replaced fork seals and bought new compressor found leak in the air line from fork to fork. hope it works bought a used airline to try. is there away to plug off air to front and put good shocks on the front? I do believe you can do that. Put Progressive springs in. But even if you do that, why drop the air? The air system works great for different loads and riding style. People have defeated the antidive system as well... Feeling it wasn't needed with the Progressive springs. Just curious...
camos Posted June 23, 2017 #7 Posted June 23, 2017 mtcowboy said: Replaced fork seals and bought new compressor found leak in the air line from fork to fork. hope it works bought a used airline to try. is there away to plug off air to front and put good shocks on the front?As mentioned, installing Progressive springs in the forks generally does not require air but even with them air is a plus. There is normally no need to be concerned about plugging off the front from the back as they are separate systems.
