Arxvz1200 Posted June 11, 2017 #1 Posted June 11, 2017 https://youtu.be/tsQJ158Rq8k adjusted valves, cleaned carbs, new gears from xvz1300, cleaned the starter motor Got her running, but still a long way to go. All ideas where to go next are welcome: I'll adjust carbs. Clutch doesn't work can work on it without draining oil, maybe tilting little Haven't checked if the battery is charging. How do check the cooling system ? What wire is to the engine temp meter ? Thanks, Anssi
