Yes that is right another starter clutch getting fixed!
So I got everything apart and getting ready to order up stuff. But need a lil help!
For the parts I need for the starter clutch I see these two on ebay
(this is going on an 87 Venture Royale)
#1 http://www.ebay.com/itm/Starter-Clutch-Gasket-Yamaha-Venture-Royal-XVZ1200-1983-1989-XVZ1300-1986-1993-/231611522167
and
#2 http://www.ebay.com/itm/Heavy-Duty-Starter-Clutch-Yamaha-VMAX-XVZ-1200-1300-VMX12-Venture-Royale-Vision/381316412272
For those that have ordered these is the price difference worth it in your opinion to get one over the other?
And the question about the middle gear: I never saw a copper crush washer when removing the cover. Does anyone the best place to order the right one? And also to order a gasket for the middle cover?
Thank you in advance for any help fellow riders'
Interesting, Both of those Ebay starter clutches only come with one of the 2 gaskets that you will need.
The first one still only has 3 rollers just like the stock one.
The second one has 6 rollers, better, but not near as good as it gets.
If you contact member @Dano, he does a starter clutch rebuild that includes all of the needed parts, and he converts it to an 18 roller starter clutch. I have the second one that he ever did and it works great. This system was invented for the guys thar are building a LOT more power into these engines on the V-Max's, where they were breaking the stock setups very often trying to turn over their high compression engines.
  • 5 months later...
If you contact member Dano, he does a starter clutch rebuild that includes all of the needed parts, and he converts it to an 18 roller starter clutch. I have the second one that he ever did and it works great. This system was invented for the guys thar are building a LOT more power into these engines on the V-Max's, where they were breaking the stock setups very often trying to turn over their high compression engines.
does @Dano still do these kits?
