Everette Posted April 21, 2008 Share #1 Posted April 21, 2008 I'm looking at placing the antenna/radio part at the back of my bike. I would run the cable under the seat. Problem: I like to take this with me in my car as well. Question: Can I splice a connector in the cable? Something like a PL259, male and female. Thanks Link to comment Share on other sites More sharing options...
Pilot Posted April 21, 2008 Share #2 Posted April 21, 2008 I'm looking at placing the antenna/radio part at the back of my bike. I would run the cable under the seat. Problem: I like to take this with me in my car as well. Question: Can I splice a connector in the cable? Something like a PL259, male and female. Thanks I don't know how many little wires are in the cable, but any wire can be cut and spiced so I would say yes. Go ahead and cut it, after that let us know the outcome. Any thing new has to first be tried by someone, you could be that someone.... Good luck with it. Link to comment Share on other sites More sharing options...
Everette Posted April 21, 2008 Author Share #3 Posted April 21, 2008 I'm not to sure about that. Don't want to ruin a $160 device. I guess I'm going to look for a extension cable to run under the seat. Everette Link to comment Share on other sites More sharing options...
dragerman Posted April 21, 2008 Share #4 Posted April 21, 2008 When I bought my antenna it came with a six foot extension cable. There must be a part number for it, try calling a radio supply store. Also, I was wondering since the cable is a USB cable a computer or electronics store should have one that will work. Link to comment Share on other sites More sharing options...
DkKnight Posted April 21, 2008 Share #5 Posted April 21, 2008 I have heard that it is not a good idea to splice any of the sat radio antenna cables. Usually they give you a pretty good run of it. I know for what I paid for my xm antenna I wouldn't be cutting on it either. Link to comment Share on other sites More sharing options...
BuddyRich Posted April 21, 2008 Share #6 Posted April 21, 2008 Your GXM-30 is a USB cable and not an RF cable. Use the extensions that came with it or buy some more if thats not enough Link to comment Share on other sites More sharing options...
SaltyDawg Posted April 21, 2008 Share #7 Posted April 21, 2008 I'm pretty confident that they are coax cables and unless you have experience with splicing very small coax I wouldn't try it. Link to comment Share on other sites More sharing options...
Everette Posted April 21, 2008 Author Share #8 Posted April 21, 2008 I found a 10' extention cable. This should work. Thanks Link to comment Share on other sites More sharing options...
lonestarmedic Posted April 22, 2008 Share #9 Posted April 22, 2008 I am checking the same thing. The hookup is USB. The wiring isn't coax. The XM receiver is in the antenna and then sends the information to the unit. So, it stands to reason that it has a power, ground, and a set of signal wires. I will let you know if I find an answer. JB Link to comment Share on other sites More sharing options...
