How many found these bolts loose?
3 members have voted
  1. 1. How many found these bolts loose?
2nd Generation Venture. Mine is an 04 with 85,000 miles on it. "BOLTS WERE LOOSE"
You have to take off side covers from both sides & passenger foot rests. Take off Plastic Cover to see these bolts that the ink pin is pointing to. My right side was out all the way. Only the plastic cover kept it from falling off onto the road. The left side was very loose. I could turn it with my fingers. I removed both bolts and put removable LocTite and torqued to 80 ft lbs. That just felt like a good feel. I could not find the torque specs on this bolt. How many bolts are loose out there running on the roads?
  • 2 weeks later...
I would check "I don't know" if it there. Never had the passenger pegs off to know. May have to take a look at that soon.
