T.J. Posted April 28, 2017 #1 Posted April 28, 2017 (edited) Tonight I was going to adjust the rear shock so I was taking off the panels on the right side to get to the top nut on the shock. You have to take the right side passenger foot pad off and take the plastic cover off. Pic #2 Pic #3 with the 14 mm bolt shown with the ink pen pointing to it was out all the way. The only thing holding it from falling off on the hwy. was the plastic cover. I put Loctite on it and tightened to 80 ft. lbs. That seemed like a good feel. Thought to myself. Better check the other side. Sure enough that bolt was very loose but not out all the way out. Just thought ya might want to check yours sometime. They are good size bolts. Edited April 30, 2017 by T.J.
