edtheguy Posted April 28, 2017 #1 Posted April 28, 2017 Where is the cruise control module thst is behind the headlight? What color are the wires? Is there a troubleshooting guide somewhere on this forum?
bongobobny Posted April 28, 2017 #2 Posted April 28, 2017 Does this help you? Look in the lower right for the cruise control unit wiring... http://www.venturerider.org/wiring/86-89%20Yamaha%20Venture%20Simplified%20Circuit%20Diagram%20Rev%20D.pdf Here's a link to the downloadable service manual from the 1st gen tech library... http://labs.trunkful.com/vrmanuals/index.cfm What kind of problems are you having?? the usual issues with the cruise control are the switches on the brake and clutch handles, more specifically the brass pivot pins wear out giving slop to the handles causing the safety switches on said levers to cause the cruise to kick out...
edtheguy Posted April 28, 2017 Author #3 Posted April 28, 2017 All the lights come on at speed (60). Does not engage.
