Skid Posted April 21, 2017 Share #1 Posted April 21, 2017 While cleaning and preforming some spring time maintenance I discovered a bolt missing. It from the bottom of the trunk mounting bracket. Any one have an idea where I can find one or best place to order? Link to comment Share on other sites More sharing options...
slowrollwv Posted April 21, 2017 Share #2 Posted April 21, 2017 Skid I may have a couple of them. I will check today and see. If mot try Boats.net. You can also take one of the other one and match it with one at Fastenall. I get a lot of bolts from them. Link to comment Share on other sites More sharing options...
etcswjoe Posted April 21, 2017 Share #3 Posted April 21, 2017 2.00 at Partzilla or Boats.net BOLT, BUTTON HEAD (8mmx20mm) 92014-08020-00 Link to comment Share on other sites More sharing options...
Rick Haywood Posted April 21, 2017 Share #4 Posted April 21, 2017 While cleaning and preforming some spring time maintenance I discovered a bolt missing. It from the bottom of the trunk mounting bracket. Any one have an idea where I can find one or best place to order? https://uploads.tapatalk-cdn.com/20170421/1cc2cc4794b6f28e1691b5385deb6b9c.jpg SKID i LOST ONE OF MINE AND i JUST TOOK THER OTHER SIDE OUT AND WENT TO ACE AND BOUGHT A COUPLE OF THEM. I also then put lock tight on them to keep the from getting loose Link to comment Share on other sites More sharing options...
Freebird Posted April 21, 2017 Share #5 Posted April 21, 2017 Everybody who owns a RSV needs to check that bolt. Put some blue loctite on it. It is known to back out. Link to comment Share on other sites More sharing options...
Skid Posted April 21, 2017 Author Share #6 Posted April 21, 2017 Thanks everyone. And also don't forget to check the bolt in the shifter that is known to come loose. Mine was loose the other day for the first time. Link to comment Share on other sites More sharing options...
Yammer Dan Posted April 21, 2017 Share #7 Posted April 21, 2017 Smith's Hardware at Big Chimney. True Value I think has a pretty good selection. Link to comment Share on other sites More sharing options...
cowpuc Posted April 22, 2017 Share #8 Posted April 22, 2017 SKID i LOST ONE OF MINE AND i JUST TOOK THER OTHER SIDE OUT AND WENT TO ACE AND BOUGHT A COUPLE OF THEM. I also then put lock tight on them to keep the from getting loose RIGHT ON RICK!! That was the very first thing that popped into my gray matter too brother!! Always amazed what one can find in those little slide drawers down there at Ace!!! Link to comment Share on other sites More sharing options...
