Doug royal86 Posted April 20, 2017 #1 Posted April 20, 2017 (edited) I have a stater side gasket if anyone one is in need of it. Free just let me know where to send it. I got it for a 86 royal. also have a universal that went on a 83 royal. A intercom cable ,not sure if it works. Possible more things if I start cleaning out the garage. Just let me know. Also blank left side dash for 86 Edited April 20, 2017 by Doug royal86
cowpuc Posted April 22, 2017 #2 Posted April 22, 2017 Doug royal86 said: I have a stater side gasket if anyone one is in need of it. Free just let me know where to send it. I got it for a 86 royal. also have a universal that went on a 83 royal. A intercom cable ,not sure if it works. Possible more things if I start cleaning out the garage. Just let me know. Also blank left side dash for 86 Doug,, if no one else has spoken up for the gasket I think I better do so.. I am still not sure if our new 83 has the stator update and I am gonna open it up - the gasket will be put to good use.. I'll PM you my home address - if the stuff has been spoken for - no problem and THANK YOU for the kind offer either way!! Puc
cowpuc Posted May 8, 2017 #3 Posted May 8, 2017 PERFECT!!!! Thanks again Doug for the gasket,, it is greatly appreciated - you da man!!!
frankd Posted May 10, 2017 #4 Posted May 10, 2017 Puc, You don't have to pull the entire cover to verify that your 83 has the stator cooling update....just pull the inner cover and look and see if it has a hole in the center of the bolt head. If you want to verify that it has the 2nd update, pull the center bolt out and see if it has the inner rod. Frank D.
snyper316 Posted May 10, 2017 #5 Posted May 10, 2017 frankd said: Puc, You don't have to pull the entire cover to verify that your 83 has the stator cooling update....just pull the inner cover and look and see if it has a hole in the center of the bolt head. If you want to verify that it has the 2nd update, pull the center bolt out and see if it has the inner rod. Frank D. Is there a procedure to pull that bolt? Sent from my LG-K371 using Tapatalk
frankd Posted May 11, 2017 #6 Posted May 11, 2017 The Yamaha manual want's you to use their special holding device to keep the engine from rotating and then use a box wrench or a socket and a rachet to remove the bolt. I usually just use my air impact gun (and a socket) to remove it without the engine spinning. Frank D.
